04-27-2011, 09:34 AM | #1 |
Newbie Join Date: Apr 2011 Location: canada
| steering problems
the problem is the steering onlys turn one way when it trys to turn the other way it makes a clicking sound any ways to stop this
04-27-2011, 09:43 AM | #2 |
RCC Addict Join Date: Nov 2008 Location: J-Braaaapin It Through Gate 10
04-27-2011, 09:45 AM | #3 |
danm i never thought of that thanks
04-27-2011, 09:52 AM | #4 |
Rock Stacker Join Date: Jan 2011 Location: Sundre, Alberta
or new internals for the servo |
04-27-2011, 09:58 AM | #5 |
Pebble Pounder Join Date: Mar 2011 Location: SLC UT
Your servo might even still be okay. First thing to check is the servo horn. If the teeth on the horn are stripped then its a much less expensive fix than getting a whole new servo. If it looks as though the teeth are not stripped on the horn then it probably is the internals of the servo itself. |
04-27-2011, 10:36 AM | #6 |
too late just got a new servo like 2secs ago
04-27-2011, 12:38 PM | #7 |
now it only turns slow like very very slow and i an't getting another servo
04-28-2011, 12:40 PM | #8 |
now it does not turn and theres nuttin wroung with the motor
04-28-2011, 12:46 PM | #9 |
Quarry Creeper Join Date: Jan 2009 Location: Estonia
| First of all, please use proper grammatic when writing. I know this is maybe too much to ask, but would be alot easier for others to read. Now, as for the problem. What did you do after the servo turned and then suddenly it doesn't? What are the vehicle specs? What kind of electronics do you have? |
04-28-2011, 12:49 PM | #10 |
its a new bright ford lighting on a new bright jeep rockcrawler, nothing, the basic new bright electronics
05-09-2011, 07:27 AM | #11 |
Same thread here..... http://www.rccrawler.com/forum/showt...22#post3084022 |
05-11-2011, 05:28 AM | #12 |
RCC Addict Join Date: Nov 2010 Location: England
are any steering links tight? they might be causing the servo to struggle.
