04-23-2006, 05:48 PM | #1 |
Quarry Creeper Join Date: Sep 2005 Location: Sydney, Australia
| servo winch question
i have read the info on the front page about making a winch but i dont know what to do once i egt up to here its say somthing about gluing sumthing. what do i glue? o yer and i alread took the bump out of that thing. this was just a practice. i am going to try it again tonight with my proper servo. i am going to use the standar savage steering servo thanks |
04-23-2006, 06:20 PM | #2 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
There is no reason to tear down the servo that much, go back and re-read "Carefully" the article, it's all pretty clear. There should be no reason at all to seperate the case. i think you're putting too much thought in to it. http://www.rccrawler.com/winch.htm |
04-23-2006, 06:29 PM | #3 | |
i only tore it down that much cause i thort you ahd to make it spin and it wasnt spinning all the way. put i guess thats cause i never tested it when it was on. o well trial and error. so i just got to work ont he top part and trim the nubs down? i read it and i dont know what to do when it says Quote:
04-23-2006, 06:55 PM | #4 |
You know the main out put gear that the servo horn attaches to, that has a small plastic or brass insert from the bottom behind the bearing, the top of the potentiometer sits in that little insert so when the gear moves in either directoin it move the potentiometer so the servo electornics board knows the position. You remove that insert so it does not spin the potentiometer. Now what the article is say is now hook up your servo to a radio, make sure channel trim is set to center on the radio. then use a pair of needle nose pliers or tweezers to turn that potentiometer to make sure the servo motor is centered and not spinning in either direction. Once set, drop a bit of ca glue on that potentiometer so it does not move out of adjustment, but only a small drop. Then reassemble. Does that help? |
04-23-2006, 11:49 PM | #5 |
so i move the potentiometer till the servo stops? then i turn the radio on, then i glue the tip of the potentiometer to the plastic? is that right?
04-24-2006, 06:17 AM | #6 | |
04-24-2006, 03:20 PM | #7 |
Quarry Creeper Join Date: Mar 2006 Location: the great brown north=(WI)
sounds like youhave a cheap servo like me heres what you do. http://www.dprg.org/projects/2003-05a/ you'll have to scroll down a bit to find it. it worked perfect for me |
04-24-2006, 07:18 PM | #8 |
yes well i figared it out even befor i got to read this. now i got to mod my control. i think i might need a switch thats has ajustble trim. can you bu switches with a forward, middle, netural and with trim so you can make it go slow? the control i will be using is the HPI TF-4. i have 2 of these controls but one is broken so is it posiple to some how get a switch thats has trim on it and put it in the one that works? also does anyone have links to peoples winches as i need to know where to mount it. to the body or to the chassie? |
04-24-2006, 08:18 PM | #9 |
Definately mount it to the chassis. You can seee mine above the front tires. Here is where the cable comes out my fairlead. |
04-24-2006, 08:20 PM | #10 |
is there a way to mod a savage control? cause i need trim on it. and now i got to find a way to mount the winch to the stock tlt chassie. i think i got an ider. thanks EDIT= what i ment was can i get a trim switch from my old controla and mod it into the new one. will this trim switch have a nutral? Last edited by brendan h; 04-24-2006 at 08:38 PM. |
04-24-2006, 08:41 PM | #11 | |
Savage radio for 4ws Please help. I'm sure you could add a centering pot but I dont know a part number. Here is the Traaxxas one: Existing screw hole, existing rear steering trim, new right and left EPA trim pots, new charging jack. From this thread: My Modded TQ3 Update - Added EPA pots | |
04-24-2006, 08:47 PM | #12 |
i think i got an ider on what to do. now my question now is will a trim switch work? cause i need an ajustible trim on it. so all i ahve to do is pull the standared 3rd channel switch out and put the new one in and make it sit the control? |
04-26-2006, 12:08 AM | #13 |
i think i stuffed up the remote i was goign to use. i am gana try fix it if it wont work i am gana get the TQ3. now do i wire up a switch to that? is it the same for all?
04-26-2006, 05:48 PM | #14 |
why do people always ignor me? i have tryed a search on putting a 3 way togal switch in a TQ3 and nothing. so has anyone got info on putting in a toggal switch in a TQ3 for a winch?
04-26-2006, 08:09 PM | #15 | |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
I know I'm not supposed to nag about spelling, but are you trying to say "idea" here? I though it was a typo the first time, the next few times I'm pretty sure that's what you're trying to say, but you keep doing it over and over. To answer what I think your question is, yes, just replace the 3rd channel switch with a knob switch, then you'll just have to find the sweet spot to center it. | |
04-26-2006, 08:23 PM | #16 |
yer i am not good with spelling. i got a 3 way togal switch. so ill put that in
04-26-2006, 08:36 PM | #17 |
| How To: Convert a Traxxas TQ3 for 4wsthis should be what your looking for
04-26-2006, 10:36 PM | #18 |
isnt that for the 4ws? or is it all the same? so basicly i got to take out the old switch and put the new one in?
04-27-2006, 06:42 AM | #19 |
that's what i got out of it. It's the same as for a winch.
