04-28-2006, 10:59 AM | #1 |
Quarry Creeper Join Date: Mar 2006 Location: TAOS NM
| TC3 crawler/trail rig hey guys i wanted to get your input on this idea i have a electric tc3 on road car my idea was to use the stock chassis but mount a stampede tranny in the middel of it and use traxxas shafts and steel yokes i will mount up some tamiya all t tiers and rims lmk wat you guys think ?
04-28-2006, 11:15 AM | #2 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
I think you would end up spending less money and have a more efficient vehicle if you just bought a tamiya kit like an F-150 or Hummer for trail duty.
04-28-2006, 11:20 AM | #3 |
Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
I have a shortened Clod body and TC3 I am doing the same thing with. Get the 200mm Rally kit, shave the chassis where the lower arms hit at full droop. Ditch the pede tranny and run the stock drivetrain, low COG. You can fit a decent spur gear on it by dremeling out the chassis, add a 65t lathe and 12 tooth pinion and you're good as far as gearing. I can't remember who has them but they do make spools for the TC3/TC4 that would be easier than trying to lock the diffs. This would also eliminate the plastic outdrives which are prone to breakage.
04-28-2006, 11:26 AM | #4 |
Gold Star Baby Momma! Join Date: Feb 2004 Location: Maumelle, Ar
Did someone say my name? this was all pre tlt/clod days for me of course. You will spend some money or not have a very capable truck. Irrang makes the spools( I have one for sale btw) It was fun to play with at first then mostly frustrating. Once I stepped up to solid axle, it was no fun anymore. I might even sell the axles too. Kevin |
04-28-2006, 02:07 PM | #5 | |
04-28-2006, 02:17 PM | #6 |
Pebble Pounder Join Date: Dec 2005 Location: Knoxville
tower has the spools http://www2.towerhobbies.com/cgi-bin...&I=LXDGD6&P=ML i run them in my goliath they are tuff |
04-28-2006, 04:33 PM | #7 |
Newbie Join Date: Oct 2005 Location: Cypress
| tc4
would the tc3 rally kit work with the tc4. and how good would the tc3 modded with the rally gear be when im just bashing in the yard?
04-28-2006, 04:55 PM | #8 |
Not very good, depends on the tires you put on it. Kevin |
04-28-2006, 09:05 PM | #9 | |
No, the only thing that swaps between the 3 and 4 are the diff housings. I don't have any pics of it, waiting until I get the spools to finish it. Still alot of smoothing out the body where I sectioned it too. | |
