06-29-2011, 04:06 PM | #1 |
Pebble Pounder Join Date: Apr 2010 Location: Guam
| What does it mean when they cut the boggers
Someones selling 2.2 swamp dawgs real cheap but he says that they're cut. What does that mean and is that a good thing? And can I put 2.2 tires on a 1.9 rim?
06-29-2011, 04:09 PM | #2 |
RCC Addict Join Date: Dec 2009 Location: Rock Bouncin' with the Patented Technique
its just every other lug cut out for better traction. I wouldn't buy the swamp dogs just because there old and out dated I would get something more modern. As for the wheels. No. 1.9 Wheels go with 1.9 tires, 2.2 wheels go with 2.2 tires.
06-29-2011, 04:10 PM | #3 |
2.2's will not work on a 1.9 rim. The inner bead dimension is to big, the wheel will fall through it. To Cut a tire, is to "usually" remove the smaller lugs. Generally, it allows the tire to "grab" rocks better and "clear" mud out of the tread easier. Sipping a tire, is to cut horizontal lines in the lugs. Also for better grip on rocks. To Vent a tire, is to poke a hole in it to allow the air out. Which also helps on rocks. |
06-29-2011, 06:49 PM | #4 |
Typically, "cut boggers" means that they have cut out the small lugs, like this: |
06-29-2011, 07:19 PM | #5 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
way to educate with a pic. |
