Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Thoughts on Losi MOA vs XR10
Old 07-17-2011, 03:59 PM   #1
Default Thoughts on Losi MOA vs XR10
Already have a berg tracer and was looking into something with more axle clearance and as i want MOA i was looking into the above mentioned rigs.
Seen the XR10 and looks good but the losi has more clearance...seen the stock comp losi and does well...BUT how does a MOA losi perform???
vti-chris is offline   Reply With Quote
Old 07-17-2011, 04:04 PM   #2
I wouldnt waste your time with the losi conversion. A few in my club did the swap and had nothing but problems. XR10 is a way better option hands down. The XR does take some parts to make it hold up to the abuse but its worh the investment.
DRCrawlGood is offline   Reply With Quote
Old 07-17-2011, 09:39 PM   #3
Ive have run both. In the end (Using stock chassis on both) and after spendings lots of money on both, the XR10 will out perform the Losi MOA.
KBrog is offline   Reply With Quote
Old 07-20-2011, 07:00 PM   #4
I don't like how the Losi MOA kit mounts the motors. Like the axles, But not how the motors stick out from the axles. Had a Losi MOA, didn't like it. Don't have a XR-10. Seen some. They did stuff the Losi wouldn't.
bigjeff1313 is offline   Reply With Quote
Old 07-20-2011, 07:58 PM   #5
www.ottsix.com
I ran a Losi MOA with a home built Tracer type chassis. I ran the front motor out level and the rear angled up about 50* It was a lot of fun, but not really comp worthy. I run Bully axles now but there are times that I miss the worm gears.
crawl-o-matic is offline   Reply With Quote
Old 07-21-2011, 04:50 PM   #6
just build the Berg, you would be better off in the long run,
T1E Chassis, some 300s and you will keep up with any xr10, or they can try to keep up with you
jeepcj776 is offline   Reply With Quote
Old 07-21-2011, 10:01 PM   #7
So the fact I have seen XR's kick the crap out of bergs too means.........
Plenty of XR's stomping on bergs and vise versa.
TexasSP is offline   Reply With Quote
