08-04-2011, 08:46 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: sweethome
| Wraith
I Have an wreckluse it has an ax 10 metal trany with vp dig and im starting to build the ar 60 axles from parts cus i love the with and off set pumpkens so my ? is will it work cus i here the Wraith uses a reverse motor.Im useing over under drive gears i have and mips i have. thanx a lot Robert |
08-05-2011, 05:01 PM | #2 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
Hmm,maybe reverse the motor? That is as easy as crossing the wires. |
08-05-2011, 06:08 PM | #3 |
wow
08-06-2011, 12:39 AM | #4 |
Newbie Join Date: Jul 2011 Location: Drifting
| This is only true if your motors are running zero degrees of timing. I'm new to crawling so sorry if that is the norm, but I've been reading a lot here and I know some folks are using 27T stock motors and 19T motors etc. For the most part those motors are 24 degrees of timing so when they are ran backward they have less RPM, power etc.
