08-08-2011, 05:24 PM | #1 |
Newbie Join Date: Aug 2011 Location: Portland
| First Must have upgrades for RTR Axial Honcho
I just ordered my first Rc crawler and it should be arriving on thursday. It is a RTR Axial Honcho. Im wanting to know what are some of the first upgrades I should do. Im not trying to comp crawler. Im really about the scale look. Just want some advice since im new to the crawling game. Thanks
08-08-2011, 05:27 PM | #2 |
start with the tranny gears, c-hubs , knuckles. go into he SCX10 section theres alot of free upgrades also. research is your friend |
08-08-2011, 05:34 PM | #3 |
Yeah i have been doing lots of looking around on forums. I just Havent seen anything bout the first must have upgrades. Ill check into the tranny gears and C-hubs. Thanks for your Help!
08-08-2011, 05:56 PM | #4 |
I joined the Band! Join Date: Mar 2010 Location: nashville,TN
the biggest MUST it mips metal drive shafts! that is the biggest MUST have! if not youll shread plastic after plastic
08-08-2011, 07:41 PM | #5 |
I have heard that. Thanks I will pick those up now. Is it a must to update my esc to one with a drag brake? And can the stock esc run a 2cell lipo? Thanks
08-08-2011, 07:48 PM | #6 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Upgrade what breaks for you. There are no must haves, different people tend to break different things. I have never had an issue with c-hubs or knuckles in 2.5 years of owning an SCX. The first thing for me was the shafts, then it moved to the tranny gears, then to the front diff gear, then to the spur gear. Some people run stock RTR SCX's with no issues. It just all depends on the owner, their driving style, and terrain. |
08-08-2011, 07:59 PM | #7 |
Pebble Pounder Join Date: Jul 2011 Location: Birmingham
Aluminum links was my best first upgrade when I got the honcho.
08-08-2011, 08:22 PM | #8 |
Thanks. Im getting the shafts for sure first. how do u guys like the esc. Whats its battery capability?
08-08-2011, 08:26 PM | #9 | |
Quarry Creeper Join Date: May 2010 Location: albuquerque
08-08-2011, 08:46 PM | #10 | |
08-08-2011, 09:19 PM | #11 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
I put in a Velineon and 3S and somehow I spun the idler gear before the stock driveshafts went. I replaced the gear and turned the driveshafts into plastic Twizzlers though. That being said, I'm with the "just driving it until it breaks" crowd. Buuut, I have a few trucks. So having one down isn't a big deal. If this is your only crawler, I'd recommend these to ensure a decent amount of time before downtime carnage.. http://www.robinsonracing.com/catalog/scorpion.html Get part 1542 and 1541. Don't even waste your time with 1540. And then get these. http://www.tcscrawlers.com/MIP-CVD-S...6-p-18175.html After that, you should be able to beat the hell out of it until you toast a C hub or a knuckle. Make sure to use loctite on the driveshafts and make sure to use some shrink wrap on the driveshafts where the pin sits. I didn't do that the first time.. Hope that helps! |
08-08-2011, 11:00 PM | #12 |
Pebble Pounder Join Date: Oct 2007 Location: St Martinville
I say steering, get solid links and scoop you up some traxxas steal yokes and shafts for the parts box and you should be good
08-09-2011, 06:50 AM | #13 |
Wow! Lots of good info. Thanks guys. Im getting my list together. I got some money to spend!
08-09-2011, 09:03 AM | #14 | |
People can spend a fortune buying other peoples must haves and never address the real issues they themselves have. I have built many RC's following that philosophy over the last 10 years and it's the wrong way to go. I now never upgrade unless it breaks or unless it's just something I like and want. Many people do well with the stampede shaft upgrade, I did not and went to MIP's. I have never broken steering knuckles or c-hubs, but know others who have. | |
08-09-2011, 09:11 PM | #15 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Id start off with m.i.p. driveshafts, robinson racing transmission gears2 ea. super soft axial scx springs, front. Rear springs soft axial scx. A 12 tooth pinion gear pinion. Thats it for a starters. Replace the servo (with a killer one you wont have to replace again or get a alum. servo saver.
08-09-2011, 09:58 PM | #16 |
Pebble Pounder Join Date: Apr 2011 Location: El Paso
get some alluminum Y's if you dont go 4 link my dad broke 3 of 'em in one night
08-10-2011, 08:21 AM | #17 |
Quarry Creeper Join Date: Sep 2010 Location: Berlin, VT
08-20-2012, 10:26 AM | #18 | |
Rock Crawler Join Date: Aug 2011 Location: tri cities
| Re: First Must have upgrades for RTR Axial Honcho Quote:
All in all its your rig and build it the way you want. You'll get people saying upgrade when it breaks but why? Why run a truck that isn't at its full potential? You can take a pinto to the daytona 500 and say "we'll up grade it as it breaks". For me, I upgraded everything first that would help the performance; shock tuning, tires, links, motor (not esc), hi clear knuckles, cvd's, 4 link front and rear, drive lines (after mine got beat up from the rocks). The best and first upgrade and I do mean the biggest... WHEEL TIME! Drive in and drive it cause the only way to get good is practice. You have to "upgrade" yourself. | |
08-20-2012, 12:07 PM | #19 | |
Rock Stacker Join Date: May 2010 Location: Boise
08-21-2012, 10:37 PM | #20 |
Rock Stacker Join Date: Jul 2012 Location: nor cal
do the scorpian ones fit the honcho?
