08-13-2011, 03:30 PM | #1 |
Newbie Join Date: Jul 2009 Location: VA Beach
| Left is right?
I don't know if I am just having a moment but I feel so lost. I am building an AX-10 and swapped the tx and rx with Traxxas set up and now the steering is backwards. I though I had the servo plugged in backwards or something bit with a tap it only plugs in one way. I'm seriously just about to learn to drive backwards lol. Any help is thankful. --- I am here: http://maps.google.com/maps?ll=36.799346,-76.121536 |
08-13-2011, 03:49 PM | #2 |
Quarry Creeper Join Date: Sep 2010 Location: Berlin, VT
There should be a switch on your radio to reverse the signal.
08-13-2011, 03:50 PM | #3 |
If your Traxxas TX has a "menu" button, then you can reverse the servo...if it doesn't have the menu button, just flip your servo over (you'll need to re-work your steering linkage if you do this) http://traxxas.com/sites/default/fil...l_100217_0.pdf go to page 30 and follow the directions for "servo reversing" (this is a slow loading page so give it time to download.) Good Luck |
08-13-2011, 04:24 PM | #4 |
Hyde thanks but it's the 2.4 not the am transmitter. Menu button is very elusive, I guess it's time to dive in and give it a look. Thanks for the link. --- I am here: http://maps.google.com/maps?ll=36.799346,-76.121536 |
08-13-2011, 05:59 PM | #5 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
Isn't there a switch to reverse the steering?
08-13-2011, 05:59 PM | #6 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Traxxas TX's have a small switch on them to reverse servo direction. Should be located somewhere around the front of the wheel below the trim adjustments. No need to turn the servo around.
08-13-2011, 06:41 PM | #7 |
on the traxxas 2.4 ones, no there is no switch for reversing anything... on the tq AM radios there are but not the newer 2.4Ghz ones.
08-13-2011, 07:34 PM | #8 |
Let me know if I can help you with the "menu tree". I've used it many times.
08-13-2011, 09:44 PM | #9 |
Newbie Join Date: Aug 2011 Location: Here not there
MY new 2.4 radio has the switch for reversing the throttle and steering .
08-13-2011, 10:15 PM | #10 |
the one he has, has a menu button...so that's the ONLY way to reverse the servo. It has no switch to do so.
08-14-2011, 09:18 AM | #11 |
really a switch? man that would make my life so much easier lol.
08-14-2011, 01:55 PM | #12 |
So it seems with the menu it's pretty simple, just follow this guide: http://traxxas.com/sites/default/fil...-menu-tree.pdf It's either a menu or a switch, either way, both controllers have servo reversing. |
08-14-2011, 02:41 PM | #13 |
Rock Stacker Join Date: Aug 2010 Location: Off the beaten path
maybe instead of a "menu" button they should add an "Easy" button |
08-14-2011, 04:04 PM | #14 |
08-16-2011, 03:40 PM | #15 |
Thanks for the help with the transmitter worked out great now up next is a new servo wit some power. Would a hirec hs-985mg do the trick? --- I am here: http://maps.google.com/maps?ll=36.799454,-76.121485 |
