09-06-2011, 02:28 PM | #1 |
Newbie Join Date: Aug 2011 Location: Portugal
| Castle Mamba Max Pro SCT HEEELP
Hi guys im new here and i got an axial wraith that just had the combo Mamba Max Pro SCT Edition ESC and Neu-Castle 1415 2400 kv motor. The thing is this setup has a tremendous amount of punch and its impossible to drive at low speed. I already tried all the configurations possible on the ESC with the remote, and even at lowest power it does the same, doesnt matter if its on a 2s or 3s. any suggestions to make this as smooth as my novak goat?
09-07-2011, 05:11 AM | #2 |
I find it hard to believe that thousands of people share the same hobby and nobody knows this!!!
09-07-2011, 05:54 AM | #3 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
Try changing the pinion. Wes |
09-07-2011, 12:26 PM | #4 |
RCC Addict Join Date: Apr 2010 Location: Ringwood
the goat is sensored the castle isnt so it wont be as smooth but get a castle link or someone near you who has one and turn on the punch control a little and make the throttle curve with a little bit of belly in it
09-07-2011, 01:16 PM | #5 |
I'm using the same setup in my scx with ar60 axles. While its not as smooth as any sensored setup, it can get smoother. Like others have said, gear down. Also, rotating the motor wires around will find the sweet spot for you. Motor wire colors don't have to match.
09-07-2011, 01:17 PM | #6 |
thanks for the advice guys. i had reasons to believe that the by changing some parameters with the castle software i could reduce the punch, unfortunatly it doesnt change significantly, and as i am using this on a "scale" trailer, its getting impossible to explore the tracks with low speeds. lowering the pinion might help controling this? wont it be too slow then? thanks in advance |
09-07-2011, 03:21 PM | #7 | |
Rock Crawler Join Date: Nov 2010 Location: Springfield, Oregon
09-08-2011, 03:08 PM | #8 |
Thanks guys, i'm always learning here. I got an answer from castle, it seems that when i did the torque limiter option it didnt actually change anything, cuz the software says its going to preform a test on the motor and does nothing. so i guess ill give it another try. this motor is a beast. its a shame if i had to let it go |
09-08-2011, 03:23 PM | #9 |
Why not drop down to 2s?
09-08-2011, 03:25 PM | #10 |
Doesnt make much diference 2s or 3s. Believe me a tried both
09-20-2011, 02:57 PM | #11 |
Guys I have news, got my hands on a Robitronic 21.5 sensored brushless motor, and i plugged it on the mamba max pro, the wierd thing is that the motor has so much stutering and coguing that doesnt even move forward/backward, i thought that motor was damaged and ordered another one, does the same thing. i tried everything with castle link, does the same, tried Smart Sensor, improves a little but still doesnt rotate the engine. Im just out of ideas here, switched the sensor wires, soldered new plugs, the motor timing is zero, doesnt move. only coguing and stutering! any ideas guys? I think im going to trash this Mamba MAX PRO ESC!!!
09-20-2011, 03:08 PM | #12 |
Quarry Creeper Join Date: Sep 2010 Location: Big hands, Little tools.......GRRRRR
What gears are you running? (How many teeth?) A smaller pinion should really help you.
09-20-2011, 05:09 PM | #13 |
Im running 20T (stock axial wraith pinion) guys i got it solved, i changed the order of the 3 Motor Wires, until i did find the perfect spot, changed dramaticly, now only has little stutering like 0,2% at the beggining. and i do believe i can fix it throw castle link. even the manual stated the order of the wires didnt matter, but it does. hope it help more people in the future, and i also want to say THANK YOU to everyone for helping me here! take care guys |
05-22-2012, 03:36 PM | #14 | |
Rock Stacker Join Date: May 2012 Location: fortaleza
| Re: Castle Mamba Max Pro SCT HEEELP Quote:
can you post some videos of your wraith with it? bashing and crawling? thanks in advance cravo | |
