09-10-2011, 09:45 AM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: Peace and Quiet
| SCX10 Options and Upgrades
Ok guys, I just ordered an Axial SCX10 RTR Kit, and was wondering what are the best/most reasonable batteries t o run, also, i was thinking about upgrading some, so was wondering what the top 3 upgrades OTHER than the esc and motor. LMK, All advice would be appreciated! TY |
09-10-2011, 10:24 AM | #2 |
Ok, as far as batteries most everyone here has converted over to lipo. You will have to investigate what the ESC is capable of handling and if it has a lipo cutoff, sorry I am not familiar with the stock electronics. If you dont already run lipo you will also need to get yourself a lipo specific charger/balancer. You will have to take some measurements of where you are going to put the battery and make sure the battery will fit, this will depend on what body you are running as different bodies have different space available. A good source for this stuff is http://www.hobbypartz.com/ As far as the top 3 upgrades that is going to be personal preference. It really depends what you like. I will list the things I think are basically necessary.
There are also a lot of cheap things you can do to upgrade the performance of your truck. Adding weight to the wheels will lower the COG(center of gravity) and make the truck roll less. You can use a bunch of different stuff to add weight to the wheels, there are stick on weights you can get at hobby shops or you can get some lead rope for fishing (bullet weights makes this and you may find it at walmart) to wrap around them or even some fat plumbers solder. For a general starting point I would add 4-6oz of weight in the front and 2-3oz in the rear. The extra weight in the front will help you when you go over something that you get high centered on, the front end will come down and now you can use the front end to pull yourself out of it. Rearranging the electronics to get them down lower will also help with keeping the COG low the most notable would be the battery as it will probably be the heaviest thing in your truck. Moving the battery plate down near the transmission is a good solution but you will have to figure out how to make it work. Also we have a section dedicated to the SCX-10 on here. I suggest you look through there on a regular basis to get ideas and tech knowledge specifically for the SCX-10. http://www.rccrawler.com/forum/axial-scx-10/ Good luck! |
09-10-2011, 10:36 AM | #3 |
Im going to be going to the Tekin FXR and 35t system.
09-10-2011, 12:05 PM | #4 |
A better upgrade would be making the tranny stronger and then some MIP drive shafts then maybe some knuckles and c,s
09-10-2011, 09:39 PM | #5 | |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
Good luck whatever you go with | |
