05-23-2006, 05:15 AM | #1 |
| replacing stock txt motor... lathe?
what is a lathe motor, whats the differenct between them and the stock txt motor i have rght now, and should i get a 35T, 45T, 55T or 65T inetgy lathe motor?
05-23-2006, 08:13 AM | #2 |
Quarry Creeper Join Date: Jun 2005 Location: NOrthern Cali
THe difference is that they have more torque than the stock can.The most common turn is the 55t.Mix of a little wheelspeed,and LOTS of torque.But,Ive seen your thread,and saw that you have a GD-600 in it.You should be fine with the stock can,gd-600,and the correct gearing--------
05-23-2006, 08:46 PM | #3 |
yeah ive got a gd600 with 2.5:1 gearing.... finally counted the teeth. ok then ill leave it alone for now.
05-23-2006, 11:07 PM | #4 |
Pebble Pounder Join Date: Mar 2006 Location: igloo, Alaska
i would buy a lathe. ud get longer run times and more torque. if u want more wheel speed then u have go with the 35 turn. the 65 turn is not what i would use with a gd600. l
