09-24-2011, 08:11 PM | #1 |
I joined the Band! Join Date: Sep 2011 Location: wilkesbarre
| what are beef tubes?
not sure what a beef tube is or what its purpose is and if there are several reasons for using them? totally confused ... |
09-24-2011, 08:29 PM | #2 |
RCC Addict Join Date: Oct 2007 Location: gervais
Not the greatest at explaining but if you have seem a pic of them, the tubes go inside the axial axles to stiffen and strengthen them plus is give you weight down low. They fit between the diff bearing and the c hub bearing
09-24-2011, 08:30 PM | #3 |
09-24-2011, 10:27 PM | #4 |
Newbie Join Date: Jul 2011 Location: Vancouver NOT BC
So are they only for Axial's? This is the first im hearing about these.
09-25-2011, 01:39 AM | #5 |
Does this allow for clocking the axle also?
09-25-2011, 03:17 AM | #6 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
TTTOtis: Yes they are only for Axial AX/SCX-10 axles. They have been out for a while...so the thread would be a few pages back by now. Scrap Value: yeah you can clock the hubs to get most caster and compensate for rotating you pinion angle up. You just need to drill new C hub holes and I drill and tap extra holes further down the axle housing to lock the tubes in good-n-proper. |
09-25-2011, 05:20 PM | #7 |
Thanx a lot it all makes sense now. LOL plus its very practical. |
09-25-2011, 08:34 PM | #8 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
| They can also make the axle more customizeable, if your willing to do some work. If you felt like it, you could cut off the stock link mounts, and fabricate new ones to mount wherever you want, and bolting them through the housing, into the tube. You could also seperate the link and shock mounting points, making BTA setups easier, etc.
10-07-2011, 11:41 AM | #9 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
The possibilities are endlessss!
