09-27-2011, 05:25 PM | #1 |
Rock Stacker Join Date: Dec 2010 Location: Australia
| I HATE MIPs
so i got some mips and had to wait 4 weeks (that fair) and when i got them i was so happy i could finaly test my scaler (i wish) after a week of messing with the stupid things trining to get them to stay togeather and fit on the car. the pin came out of the front shaft and shreded me spur gear, then today on its first run the rear had the same problem but this time i cant find the parts so i need to find a pin (i can probly make that) and also the barle that the pin gose into |
09-27-2011, 05:36 PM | #2 |
Hoof Hearted? Join Date: Nov 2009 Location: Chattanooga
I'm guessing you are talking about driveshafts. You have to make sure and get all those set screws that hold the pins in good and tight to keep them together. A little lock tight helps too. I've had a set for about 2 years and had no problems with them. I know it sucks to have to rebuild brand new parts, but MIP has rebuild kits for those shafts. It may have the parts you need. Hope this helps. |
09-27-2011, 07:21 PM | #3 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Loctite is your friend and I believe the MIP instructions also tell you to use it. You can get the CVD rebuild kits for the MIP's that include pins and set screws.
09-27-2011, 07:32 PM | #4 |
Quarry Creeper Join Date: Jun 2007 Location: Idaho Falls
My mini crawler has been running them for two years and I beat on it pretty hard. Loctite and proper assembly. Maybe I'm just lucky. I was going to put them on my rock racer, but went with the metal end Stampedes.
09-27-2011, 11:20 PM | #5 |
RCC Addict Join Date: Nov 2006 Location: burlington
blue loktite and a good backup incase the set scew falls out for some reason, heat shrink tube over the ball that has the pin in it.
01-18-2013, 02:56 AM | #6 | |
Pebble Pounder Join Date: Sep 2012 Location: Queensland Australia
| Re: I HATE MIPs Quote:
With all the hype of how good they are, MIPS needs to get with times and provide the pin screw - how much would it cost them. I just installed mine and then removed them because I won't run a drive shaft with a grub screw - regardless of whether I have a faced shaft or not. Last edited by Holdencars; 01-18-2013 at 04:09 AM. | |
01-18-2013, 03:25 AM | #7 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
| Re: I HATE MIPs
I use loctite when assembling and will also setup about a 1/2" wide piece of shrinktube over the joint as a secondary support to ensure the pins/set screws dont come out. I run MIP on 3 rigs and have never lost anything. Proper assembly will get ypu longer life
01-18-2013, 08:49 AM | #8 |
| Re: I HATE MIPs
I Love my mips an won't ever run anything else! Got em on 4 rigs soon to be 5, loc-tite for sure an a good wrenching down.. I have a friend that had a similar issue but wouldn't give up on them.. we Musta waisted an hour of crawling for him to keep loosing parts.. the one time was a whole half the shaft down in a gap in the rock.. he is still running them. |
01-18-2013, 08:56 AM | #9 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
Through pins would deff be nice but not every rig is setup to use them. I also have issues with everything coming loose. I have used every type of lock tight there is. With enough red most things hold for quite some time but never forever. If your looking for another driveshaft - use traxxas. They aren't quite as strong but are cheaper. MIPs will always be on my high power and abused rigs. Strongest setup available. |
01-18-2013, 09:12 AM | #10 |
| Re: I HATE MIPs
I just got some Jun-Facs, but this question is still pertinent to this discussion. I got LocTite Gel in both red and blue. Now do I use red on the setscrew holding the pin, and blue on the the screws that grab the output/pinion shafts? Or just go red on everything? |
01-18-2013, 09:22 AM | #11 |
| Re: I HATE MIPs
I'm contemplating the Maxx shaft route. Only problem is you need the extended outputs for the tranny. Crawler Innovations sells a kit for about 50 bones.
01-18-2013, 09:25 AM | #12 | |
Rock Crawler Join Date: Sep 2011 Location: truckee
Tapping the yokes to 4mm helps a ton keeping them in place. | |
01-18-2013, 09:28 AM | #13 |
| Re: I HATE MIPs If you do go this way, I recommend using female shafts at both the trans and diff ends and just gluing a male into one of the female. This setup will be much stronger. |
01-18-2013, 09:32 AM | #14 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
| Re: I HATE MIPs
You only need to use a drop of Loctite. Gooping it on will actually make it less effective. You should also brakleen off the thread area and ensure its perfectly clean. Pickout any old Loctite and let it set for 24hrs before using it. My slash, Rustler, scx10s all use them. I spray dry graphite lubricant on tem as well every few runs helps a lot to keep them running smooth. If its still coming loose use some Loctite 640 sleee retainer. It will be in there forever. But really if your threads are clean and undamaged they should hold fine with Red Loctite.
01-18-2013, 09:57 AM | #15 |
RCC Addict Join Date: Jun 2010 Location: fort collins
| Re: I HATE MIPs
I have been running mip's for 2 years with no problem. I used blue loctight and waited about 12hrs to drive it. Running them on my ax-10, and wrekluse.
01-18-2013, 12:45 PM | #16 |
| Re: I HATE MIPs
Junfacs any better. I'm looking to buy in the next week or so.
01-18-2013, 01:24 PM | #17 |
| Re: I HATE MIPs
I've never used the JunFacs, so I can't speak for the materials and durability. Pretty much the only reason I went with them was that I could find info on the lengths of shafts I needed. Had I been able to find out what lengths of MIPs to use, I'da probably bought them instead. Only thing I've seen so far that I'm not thrilled with is that the D shaped hole in the female end of the drive shafts seem to be only 1/4"-3/16" deep. I've never seen/heard of anyone ever tearing the cap (if you will) off of the rest of the hollow tube, so I'd have to believe it'll be fine. Not saying it's at all insufficient, I just thought that was machined a lot deeper in there, that's all. And I don't know, the MIPs may be very similar, I've never seen one. |
01-18-2013, 01:49 PM | #18 |
| Re: I HATE MIPs
I have beat the snot out of my MIP's with no complaints from them for two hard seasons and many scale runs. I even took some piano wire and used it to replace the pins when they were looking a little worn.
01-18-2013, 01:51 PM | #19 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: I HATE MIPs
This thread does not deserve to be in General Crawlers, moved to Newbie General. BTW, I hate kids. |
01-18-2013, 02:04 PM | #20 |
Quarry Creeper Join Date: Dec 2011 Location: The land of snow
How did it take you a week to get them together and on the truck? Have you ever used a hex driver before? I built and installed mine in 20 minutes.
