05-28-2006, 03:45 PM | #1 |
Newbie Join Date: Apr 2006 Location: Cedar City
| HELP!!! Wiring i don't know how to do it.. Hey all thanks for taking time out to read this, i need help in wiring my new crawler because i don't want to burn anything up. I have a set of cod axle so that is 2 motors. I'm running a Novak XRS speed control with 1 battery for now, and tq3 3 channel radio. So how do i wire the 2 motors up and speed control up. Thanks everybody....... Eric erockshws@yahoo.com |
05-28-2006, 03:49 PM | #2 |
Like this. P.S. If you plan on running a second servo for rear steer, You'll need a different ESC or a Novak Nitro Regulator for the XRS. Good Luck Last edited by dezfan; 05-28-2006 at 05:07 PM. |
05-28-2006, 04:58 PM | #3 |
Why do i need a different esc with rear steering??? , and yes my crawler is setup with rear steering... Eric |
05-28-2006, 05:07 PM | #4 |
The bec on the XRS doesnt put out enough juice for two servos doing crawling duty. If it is workin for you then keep at it, but when your servos seem weak or slow it is the ESC's fault.
05-28-2006, 05:08 PM | #5 |
The XRS BEC isn't high enough to handle 4WS. It's onlt rated at 1.5 amps. (Edit) Looks like JRH beat me to it! |
05-28-2006, 05:46 PM | #6 |
ok so what esc is a good one, but still affordable?? for the crawler??? Eric |
05-28-2006, 07:50 PM | #7 |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
| If you don't want to have to go out and purchase a new ESC you can get the Novak Servo Regulator and have enough juice to power both the servos. Or, if you do get a new ESC get something like the Tekin Rebel 2 (or a Novak Super Rooster, if you can find one.). They have enough voltage and amps inside to power dual servos. |
05-30-2006, 08:39 PM | #9 |
Rock Stacker Join Date: Mar 2006 Location: columbus
or you can make your own regulators for your servos from radio shack parts for about $10 and keep your esc.
