12-08-2011, 12:26 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
| benefits of dual esc
Other than motor biasing, what other benefits does having dual escs vs. 1 esc and punk dig have? Can the rear motor be biased more than 100% I understand slowing the rear motor down for steep inclines.
12-08-2011, 04:13 PM | #2 |
Quarry Creeper Join Date: Nov 2010 Location: Canada
Its all about the proportional control. I use it everytime I drive. It can make lines effortless when you get the hang of it. You can tune out stall on the fly. A to your Q, Instead of going more than 100% in the rear you slow the front down. Rare instances require this but I have used this feature numerous times. The more you drive the more you will see how much benefit it is. 1 ESC+ punk dig is like a clodstalling shafty with more ground clearance. Half way to a MOAs potential. If your building a crawler from scratch, it is not anymore expensive really. The onlky time I could see a single esc setup being recommended is if you have a Spektrum and wanna keep it. Which I don't understand at all. Horrible radios. |
12-08-2011, 06:31 PM | #3 |
When my son first built my 2.2 Bully comp rig for Christmas last year, it had a single ESC and a servo dig. It worked well. Then I converted it to dual ESC's with a WantAmix to work with my Futaba 3PM-x. Much better. You can set it up to underdrive/overdrive either end a bit if you want, then you can dial in more/less bias depending on what you want to do. You also still have full front/rear dig (just like a Punk dig or servo dig). If I had a choice (and I do, actually) I would pick dual ESC's on a MOA. |
12-08-2011, 06:35 PM | #4 |
| I turn the rear up to 120% to make gap jumps and various uphill climbs that need it.
12-09-2011, 01:44 AM | #5 |
thank you for all the replies. I like the idea of being able to turn either motor up over 100% Thought one could get rid of clos stall with smaller pinion in the rear. I was considering going the easy/lazy way with one esc. But i don't want to limit rigs potential. I need all the advantages i can get. lol Once again. Thank you all
12-09-2011, 05:56 AM | #6 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
12-13-2011, 02:13 AM | #7 |
Newbie Join Date: Dec 2011 Location: UK
I know this thread is quite old but with the release of the Novak M2 would anyone fill me in on its performance over dual ESC +DIG.
12-13-2011, 09:49 AM | #8 | |
As to dual ESC's, depending on your radio you can do dual ESC's with dig/mixing (proportional) straight from the radio or with an external device (like a WantAmix) to run dual ESC's. Either way, you do NOT need a "dig unit" with dual ESC's. I had a single ESC with a servo dig on my 2.2 MOA. It worked OK, now I'm running dual ESC's with a WantAmix for my Futaba 3PM-x (3 channel radio). It works a lot better, has dig & front/rear mixing. | |
