12-21-2011, 10:47 AM | #1 |
Newbie Join Date: Dec 2011 Location: Heber City
| Motor startups
I have recently finished my XR10 and took it out for the first real run. I began noticing that when I was starting a climb that the front axle started before the rear by a small but noticeable amount. Is this what is refered to as Clod stall, what might I do to remedy the problem, any help would be apreciated. Thanks.
12-21-2011, 11:37 AM | #2 |
Newbie Join Date: Dec 2011 Location: Illinois
| Re: Motor startups
My speed control has a setup for this. What ESC are you using? maybe this was enabled?
12-21-2011, 12:09 PM | #3 |
| Re: Motor startups
Single ESC & dig, or dual ESC?? What radio?? If a dual ESC depending on the radio, you could add some proportional to one motor or the other to help this out. |
12-21-2011, 12:40 PM | #4 |
| Re: Motor startups
when climbing your rear motor has more of the weight so it stalls easier causing the front to still run which is clod stall. if running 1 esc put either a 1t smaller pinion in the rear or 1 larger in the front to help lessen the clod stall
12-21-2011, 03:17 PM | #5 |
| Re: Motor startups
I am running one esc the M2. I know a lot of people say it sucks but I guess I will see. I am running the Futaba t3pm mx. I will try the pinion change, I was thinking of changing them both already to get a little more torque out of the motors. Thanks guys.
12-23-2011, 06:06 AM | #6 | |
| Re: Motor startups Quote:
I run a 3PM-x, dual FX-r's & a WantAmix in my 2.2 MOA Bully rig. As to the M2, I've read about a lot of issues, especially with the early ones, don't know if they finally fixed the issues. I "fix" clod stall by changing the propo via the WantAmix. Running slightly different pinions can also help. | |
Motor startups - Similar Threads | ||||
which motor novak 55t motor or integy v10 professinal 75t | hpiontherocks | HPI Wheely King | 0 | 08-04-2008 03:36 PM |
