01-19-2012, 11:13 PM | #1 |
Rock Crawler Join Date: May 2008 Location: in a small town
| solder help
what solder is best to use on esc's and motors? im a total newb when it comes to this.....so flame on if ya want, but atleast shoot me in the right direction first |
01-20-2012, 01:46 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
| Re: solder help
Just get some good quality 60/40 solder and you'll be good!
01-20-2012, 07:06 AM | #3 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
| Re: solder help
Also make sure to get the thin stuff, not sure the diameter but it's about 1mm (yeah, yeah, us canucks are metric). It'll be much easier to solder little connections when you have to.
01-20-2012, 07:11 AM | #4 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
| Re: solder help
most rookies get plumbing solder or the stuff labled "electronics solder" from the hardware store (even that stuff is like 1/8th thick, my friend swears by it, it's terrible), I used 60/40 rosin core .030, Radio Shack will have it.
01-20-2012, 09:12 AM | #5 | |
| Re: solder help Quote:
Do NOT get plumbing solder (usually no internal flux and can be hard to get hot enough with an iron). Do NOT get acid core solder, it can eat circuit boards! RadioShack, decent hardware store, PC building store, etc. can all carry "electronics solder" which is usually thin rosin core solder. | |
01-20-2012, 06:51 PM | #6 |
| Re: solder help
The best solder I found is Deans Solder: Deans - Solder The Radio Shack stuff is ok, but you can tell the difference. |
01-20-2012, 07:58 PM | #7 |
Newbie Join Date: Jan 2012 Location: Las Vegas
| Re: solder help |
01-21-2012, 12:04 AM | #8 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
| Re: solder help
Yup another one for 60/40 rosin core...Make sure you get it from an electronics place and you'll be golden. The stuff i use is from Jaycar here in Oz (same as radio shack). It's cheap, and works just as well as all the expensive stuff I've ever tried.
01-21-2012, 08:58 AM | #9 |
Pebble Pounder Join Date: Dec 2011 Location: USA
| Re: solder help
not to jack a thread...just had a relevant question...the solder i use says silver solder...it is very thin...is this good or should i use something different...
01-21-2012, 02:20 PM | #10 |
RCC Addict Join Date: Apr 2006 Location: Brighton
| Re: solder help
Deans and the Radio Shack stuff work good. Most people use too hot/too big of a soldering iron. Most of my RC soldering is handled with a weller 25 watt pencil style iron. I have a couple of butane irons for field repairs (If somebody else has needed it) and a 40 watt weller pencil iron for bigger stuff (NOT RC). A good soldering station(AKA 3rd hand) will save you a few blisters...ask me how I know |
01-21-2012, 03:11 PM | #11 |
| Re: solder help |
solder help - Similar Threads | ||||
did i solder this right? | m1009cucv | Electronics | 6 | 07-08-2011 06:34 AM |
solder | 4ruggy | General Crawlers | 6 | 12-31-2008 11:22 PM |
Solder - What are you using? | asfasasu3 | Electronics | 13 | 06-27-2008 08:04 PM |
Never Solder before? | Keiger | Electronics | 9 | 02-06-2005 07:12 AM |
