01-23-2012, 05:20 PM | #1 |
Pebble Pounder Join Date: Oct 2011 Location: Kansas City, MO
| Axial SCX10 MIP's with WB8 inputs/outputs?
I want a strong driveshaft setup with through-pins in the inputs/outputs like the Wraith (WB8 inputs/outputs), don't want to trial and error, don't want to spend a ton of money mixing and matching parts. Will the Wraith MIP's fit on a short wheelbase (11.3") SCX10? I've considered using Maxx shafts but that's a lot of work for a setup that still uses set screws (more or less as the screw doesn't go through). How do the MIP's compare to the Maxx shafts? Since they're steel, I'm assuming they'll hold their own? Hold up to brushless (Velineon, probably) well? Thanks for putting up my barrage of questions. |
01-23-2012, 08:46 PM | #2 |
| Re: Axial SCX10 MIP's with WB8 inputs/outputs?
I've never saw or even heard of an MIP Axial driveshaft breaking, I have saw them break a Robinson Racing one piece locker, you'd have to run 300's to even have a chance at breaking one before an axle shaft. I doubt the Wraith shafts will fit that short wheelbase. I don't get the new rage about the through pins anyways. I've never had a setscrew back out with quality lockers and gears that are required for big power anyways. A through pin has to much of a chance to bend and get stuck IMO.
