02-28-2012, 09:14 AM | #1 |
Rock Stacker Join Date: Dec 2011 Location: San Diego
| wheel base and bent links?
I am about to do the 540 upgrade from ZNO on my rs10 and since i will have to bend the lower links to clear my motors Im worried about altering my wheelbase too much. I'm wondering if anyone knows the standard wheelbase for 2.2 comp crawlers down here in San DIego? Thanks in advance, M. |
02-28-2012, 09:33 AM | #2 |
Rock Crawler Join Date: Jan 2008 Location: Calgary Crawlers, Alberta, Canada
| Re: wheel base and bent links?
2.2 rules say no longer than 12½ inches, most people run slightly under that to make sure they're never over. Bending your links won't change the wheelbase very much unless you go for a severe angle.
02-28-2012, 11:06 AM | #3 |
thanks dude... i dont know how much Ill have to bend the links yet to clear the motor but I knew I had to keep my wheelbase in mind while doing it... M. |
02-28-2012, 01:07 PM | #4 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
A 30 degree bend towards the end of the link will reduce the eye-to-eye by about 1/8" - 3/16" depending on the total length of the original length....if your original link was 5"...you may be reduced to about 4-7/8" or 4-13/16" depending on your suspension setup, and if you did both front & rear the total WB loss could be about 1/4" - 3/8". This could be rectified with adding a small spacer to the end of the link to compensate, or a longer rod end trimmed to make up the difference. I know that I would not want to lose 3/8" of WB in my comp rig, so I would adjust as necessary.
03-02-2012, 09:23 AM | #5 |
Pebble Pounder Join Date: Feb 2011 Location: Knoxville
Or you could make some links, bend them for clearance then cut them to the length you need.
03-02-2012, 03:09 PM | #6 |
Newbie Join Date: Dec 2004 Location: Phoenix, AZ
You could use this formula to build bent links and have them come out the correct length without having to trim them after they are bent. Length of tube consumed in a bend = CLR (center line radius) (center line radius) x DOB (degree of bend) x .01745 Click Here for a diagram. |
03-02-2012, 06:06 PM | #7 |
^yeah or that.
wheel base and bent links? - Similar Threads | ||||
bought Ax30524 links to shorten wheel base on honcho and can't install them | sebastien^_^ | Axial SCX-10 | 8 | 08-02-2011 08:37 AM |
honcho on a small wheel base? and advantage of the long wheel base? | Daddydancool | Axial SCX-10 | 7 | 04-26-2011 06:29 PM |
Be careful with your Losi bent links / DIY bent links as a result | Russ | Losi Mini-Rock Crawler | 14 | 01-06-2009 04:43 PM |
