07-21-2006, 03:08 PM | #1 |
Newbie Join Date: Jul 2006 Location: bend
| started rock crawler project
using T maxx axles and locked out independent suspension as solid axles and plan on using the T maxx tans with the 55 turn integy motor I got. was planning the stampede gear box originally but I like the way the T maxx trans has a brake, reverse and the driveshafts will be much easier to work out. what do you all think about the T maxx trans for a crawler? also, need to find a few places where I can buy the big heims for the links and figure out what thread they are so I can go pickup some aluminum tubing or rod and get started on the links going to make my own frame.. looks tricky but that's what I want to do and it's less expensive that way and on top of all, I don't think anyone makes a frame that will fit a T maxx trans ans stuff any input is appreciated, thanks |
07-21-2006, 03:16 PM | #2 |
k, well, forget the fact that the t maxx trans has reverse since I don't need it.. I just had the epitome that I was dumb enough to forget that the electric motor does reverse.. oh I feel stupid now. anyways, I also heard there is a centrifital clutch to go into second in the t maxx trans. anyone know how to lock that out as well as the reverse on the t maxx trans? thanks
07-21-2006, 03:42 PM | #3 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
First things first, welcome to RCCrawler.com! You said you're going to make your "frame", does this mean you're making a tuber? If so, I would advise you to fabricate something more simple for a first build, like an NN immitation as it is simple and still a great performer.
07-21-2006, 03:59 PM | #4 | |
thanks | |
07-21-2006, 04:09 PM | #5 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Looks like you have your mind set on what you want. All you need to do is start it. The best way to achieve your goal is trial and error in this Crawler world. If it doesn't work then you know what not to do. There is a lot of good reading on here. So use the search and start reading. And building a frame around the Tmaxx tranny isn't to difficult so you sould be good on that one and there is a thread on how to lock it into 1st. Search and you find it. I don't have the time right now to get the link for you. Good luck and welcome aboard |
07-21-2006, 11:29 PM | #6 | |
