07-25-2006, 06:58 PM | #1 |
Quarry Creeper Join Date: Apr 2006 Location: Ready to rock!
| Gears
So im starting my scale build, i have almost everything i need, but what kind of pinion gear should i use for my pede tranny?? would the stock tlt one work? i want a really good torquey truck that can climb anything it grabs, but not sacrifice too much speed. thanks for any help
07-25-2006, 08:29 PM | #2 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
11tooth and 12tooth is the most common 12 is much easier to find even more than gear ratio motor choice is very important 45t 55 65 75 can compensate for lack of ratio as well as adding cells to a battery pack for a little extra punch
07-26-2006, 02:40 AM | #3 | |
Rock Crawler Join Date: Sep 2004 Location: a place of settlement, activity, or residence.
The stock TLT pinion is metric 48 pitch and will only work with metric spurs, You will need to pick up another one that is standard 48 pitch. I have my trail rig set up with a 12/87 combo that is pretty low. I would start around a 14 tooth and go from there. | |
