Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: locking txt front diff
Old 08-13-2006, 12:50 AM   #1
Default locking txt front diff
im thinking about locking my front diff but the turning circle is bad enough with just the rear locked. i only have front steer will it make the steering real bad if i lock the front up?
460cixy is offline   Reply With Quote
Old 08-13-2006, 01:18 AM   #2
John Deere's Avatar
YES!!! It will make it alot whorse if you lock the front. But honestly, go ahead and put a rear steer on that thing and that will help you alot even with just the rear locked. Rear steer does a wounder man.
John Deere is offline   Reply With Quote
Old 08-13-2006, 01:31 AM   #3
im cleaning the grease out as we speak ready for the epoxy. it will be getting 4ws just a matter of time. just when i was out today there was so many places it would just spin the wheels and one front tyre still had good traction just no drive going to it cause the other one was an inch off the ground
Old 08-13-2006, 02:44 AM   #4
well its locked and there steering sucks bigtime its ok in reverse but crap going fowards i realy need to get my finger out and do the 4ws setup
Old 08-13-2006, 12:04 PM   #5
now you actually climb over rocks. really work on that 4ws you need it
kaaina is offline   Reply With Quote
Old 08-13-2006, 01:35 PM   #6
Wink
i locked mine and i had 4 wheel steer and every time i went to crawl it kept on stopping and going so i took out the 4 wheel steer and it crawled a lot better. LOCK THEM BOTH IF YOU WANT THE BEST PERFORMANCE AND KEEP 2 WHEEL STEER!
Moondust1950 is offline   Reply With Quote
Old 08-13-2006, 03:45 PM   #7
all i need 4 4ws now is is a dremil
Old 08-15-2006, 01:20 AM   #8
sounds like an esc problem some esc don't have an high enough bec or just a low battery 4 wheel steering is a must for making some tight corners
Old 08-30-2006, 02:05 AM   #9
well i made some crapy mounts from the rear steer and it rocks big time tight turns ect but broke the servo case when i stacked it its very un protected just sort of hanging out the back
