08-18-2006, 01:23 AM | #1 |
Quarry Creeper Join Date: Jul 2004 Location: 808
| gd600 / pede ??
Is anyone else having this problem? I trimed my pede tranny and gd600 so they would fit, but now when I get a tire just a little bit wedged or on initial start Ill start to strip the spur. The case is flexing near the motor mount and alowing the pinion to move away just enough to strip the spur a little bit. Is anyone else having this problem? or anyone know how to fix it (other than buying an aluminum tranny case.) |
08-18-2006, 01:50 AM | #2 |
Nope.. Join Date: Aug 2005 Location: Whiteland, Indiana
There's an aluminum motor mount plate off a Tamiya touring car you can get to bolt onto the front of the tranny. I don't remember what one though. TA03 maybe?
08-18-2006, 08:07 PM | #3 |
Quarry Creeper Join Date: Apr 2006 Location: Gervais
He just said not to. You could get matal spears. Or change the gear mesh.
08-18-2006, 08:13 PM | #4 | |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
OH and here are some matal spears for ya | |
08-18-2006, 08:38 PM | #5 |
| I don't suppose you might know if that Star of David is a direct drop-in for a pede tranny, do you?
08-19-2006, 01:22 AM | #6 | |
08-19-2006, 01:54 AM | #7 | |
08-19-2006, 11:24 AM | #8 |
Rock Crawler Join Date: Nov 2005 Location: Oak Ridge
08-19-2006, 07:46 PM | #9 | |
Quarry Creeper Join Date: Jan 2006 Location: Jonesboro, TN
I've been looking for one of those ever since I found those instructions about a year ago. You don't where to get anymore of them do ya. | |
09-22-2006, 10:26 PM | #10 |
Just thought id post this up if anyone cares. So I found a simple way to make a metal motor plate for the pede tranny. Im sure most of you still have the stock motor plate that comes with the tlt kit...right? Well with a little trimming it will fit, it does not interfere with any thing and seems to work and the holes line up. In both pictures, there is one extra part that needs to be trimmed off of the plate so the output shafts will clear. I still never found a solid way to keep the f'n gear mesh right though. Ive made little brackets in the back to hold the gd in place, but when bound up tight, it will still skip and strip the gears.....fuk. |
