08-20-2006, 07:17 PM | #1 |
Quarry Creeper Join Date: Oct 2004 Location: Canada eh!
| Belt skipping
I got my truck together with my new chassy and everything, was going good, get the new truck out side go to crawl and the lower center diff i guess you call it is spinning when you get into any load so the front would only move, so i took it out, locked it and then put everything back together and tried it and when you start to crawl and put load on the truck the belt skipps like crazy and clicks like crazy too, so i thought it was maby the pinion wasn't close enuff to the spur, but thats fine maby little too close actually, but when i watch the belt when holding onto the truck its turing up top just must be skipping below, how can i fix this besides going with a xxxt, or a stampede, tranny, im leaning towards the xxxt tranny, is that a good one to go with? anyways is there any way to fix it befor i get a new tranny? is this why everyone switches trannys becz the stock one sucks? thanks |
08-20-2006, 07:22 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
Your best bet is to ditch the stock tranny, in favor of something stronger. You could fab up a belt tensioner, to tighten the belt up for now. |
08-20-2006, 07:42 PM | #3 | |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
08-20-2006, 08:24 PM | #4 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
if you get a different tranny send me the stock one, i might be able to do something to fix the belt slipping. ill send it back of course.
08-20-2006, 11:21 PM | #5 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
if you cant afford to get a real trans, you could fab up a tensioner of sorts for the belt. i tried a spring loaded tensioner but ended up making a fixed tensioner using some bearings, spacers and a short link rod from the kit. i ran countless batteries through that truck on the original belt with no issues before robbing the axles for another project. just set it up a little tighter than you think it should be and try it out. |
