12-23-2012, 08:29 PM | #1 |
Newbie Join Date: Nov 2012 Location: Where I Live
| Axial AX10 Scorpion
Hey guys, I'm a newbie to RC crawling, and I've had this AX10 for two years. I've run it a lot, just not real rock crawling (don't have enough rocks). I'm running a Novak High Torque motor, an Axial AX-2 ESC, and a Venom 3300 mAh NiMh pack. I have 2.2 Axial Rock Lizards on bead-lock rims. I'm planning on getting a 1992 Jeep Cherokee body, painting it up like a police car, getting a Traxxas Police Light Bar, and a HobbyPartz LED Kit. I'll be posting pictures in a little bit. My camera needs to be charged.
12-24-2012, 08:04 AM | #2 |
RCC Addict Join Date: Jul 2009 Location: Dover, NH
| Re: Axial AX10 Scorpion
If you want to make it more scale friendly and realistic then pick up one of these: Axial SCX10 Frame Set All of your axles and trans, etc will transfer right over. It will be much easier and look better with the Cherokee body. You may hve to do some adjustments with the axle links and what not, but it is a simple swap all together. Maybe some smaller 1.9 wheels and tires would be nice too. The Cherokee has very small wheel wells making it hard to fit large tires without the tires rubbing. Good luck which ever way you go. |
Axial AX10 Scorpion - Similar Threads | ||||
Axial Scorpion AX10 Axle Give-A-Way **Free AX10 Axles*** | Rockpiledriver | Axial AX-10 Scorpion | 297 | 08-27-2007 06:15 AM |
Just order the Axial AX10 Scorpion | Azcats1 | Chit Chat | 0 | 04-21-2007 05:58 PM |
