08-26-2006, 08:10 PM | #1 |
Newbie Join Date: Jul 2006 Location: ontario
| mounting tires
ok i have standard clod axles and i wanna mount 2.2 wheels and rims on it, that i just purchased, but when i go to put them on it jsut docent fit right any eerythign, so what part do i need to addpt these to fit, hook me up with a link, ill prollyg et it off ebay or somthing. k thanks.
08-26-2006, 08:15 PM | #2 | |
It is very hard to understand your post which will make it hard for members to help you w/ your problem. Now, try a set of Traxxas Stampede (front) wheels. They have a 12mm hex as does the Clod. Problem is solved. Last edited by dezfan; 08-26-2006 at 08:18 PM. | |
08-26-2006, 09:00 PM | #3 | |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
Let us know what kind of wheels you purchased to put on the Clod axles. Virtually all 2.2 wheels with a 12mm hex on them should fit. Do your's have a 12mm hex on it? If you got pics of the inside of the wheel, or even a close up of how it 'jsut docent fit right any eerythign' (I'm betting that you're trying to say: 'just doesn't fit right and everything'?). | |
08-27-2006, 06:49 PM | #4 |
i was unaware of things when i purchased my rims, there traxxas dish rims #1974 and there is no hex or anyhting at the back, its just round. is there a way i can solve this problem without having to purchase new rims??? although i woudlent mind a new pair as these are kinda ugly, prolly look alot better once i graphitti them.
08-27-2006, 11:58 PM | #5 |
Quarry Creeper Join Date: Jul 2004 Location: 808
You are going to need new wheels. I did not look up which set you bought, but Im pertty sure you bought front wheels for a Bandit or Rustler. They have no hex, just a space for bearings. You are going to want to pick up a set of Stampede front wheels, or a set of HPI or RPM universal wheels.
08-28-2006, 09:47 AM | #6 |
Newbie Join Date: May 2005 Location: Sicamous BC
You got Nitro truck fronts, they use a different hub system than an electric truck. I would get some electric Rustler or 'Pede fronts.
