09-08-2006, 04:46 PM | #1 |
Rock Stacker Join Date: Oct 2005 Location: Montréal!
| easy question just need some one to answer it ...
shame on me because i ask this but man i need to know. if you take the e-maxx tranny i your hand and look at it to the side with the spur on wich way does the spur need to turn in order to have the truck going foward. it would be dumb to mount the tranny backward ... |
09-08-2006, 04:51 PM | #2 | |
RCC Addict Join Date: Apr 2005 Location: Eden Prairie, MN
Technically you can mount it in either direction, mount it the way that suits you the best. If the truck goes backwards, you can always just switch the wires on the motor. Otherwise... In my 'stock' e-maxx, the spur gear is facing the rear of the truck (motor endbells facing the front). Hope that helps... | |
09-08-2006, 04:53 PM | #3 |
alot! thanks but ist it harmfull for the lathe motors to run them backwards? |
09-08-2006, 04:55 PM | #4 |
my crawler is built with savage axles instead of e-maxx axles and they turn opposite ways!!! :-( can i run the tranny/motors the way i need to make the truck go foward? |
09-08-2006, 05:01 PM | #5 |
RCC Addict Join Date: Dec 2004 Location: Central NY
It will not hurt the motor. How do you think they go in reverse? And do what ever you need to do to get it moving forward.
09-08-2006, 05:04 PM | #6 |
rock on! i'll go take piks to start my build thread!
09-08-2006, 08:13 PM | #7 |
RCC Addict Join Date: Mar 2005 Location: Saginaw
Just make sure the motors are set at zero timing. I think lathe motors are neutral timed from the factory, but it's just something to keep in mind.
09-09-2006, 10:11 AM | #8 |
| I've now had at least 7 different Lathe motors go through my hands and every one of them has been set at 0* timming from the factory. Another option for those who do not want to 'just switch the wires around' is to axctually rotate the endbell 180*. That will 'reverse' the rotation of the motor. |
