09-13-2006, 01:56 PM | #1 |
Newbie Join Date: Sep 2006 Location: under a rock
| Battery Building
I have some matched cell sticks and I'm going to split them to run on my axles.What is the best way to build these and do they need to be discharged before starting.
09-13-2006, 02:46 PM | #2 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
No they don't. Be sure to use a very hot soldering iron so you can solder fast and not heat up the batteries too much.
09-14-2006, 01:00 AM | #3 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
I did this, didnt discharge... u may get some sparks ... I know I did what kinda axles are u building them for?... I have some good ideas for both Clod and TLT axles... can help u if needed |
09-14-2006, 09:17 AM | #4 |
I'm building them for TXT axels.I have to get the COG down alot.I aready have a good idea of what I need to do to the truck ,Hack the frame ,move the shocks,and lower it alot.Also i'm putting a GD 600 on it and remounting the tranny on its side...... ..So do I need a special solder for this batt. build? I already have the bars,wire,shrinkwrap. I just want to be sure before I start.
09-14-2006, 01:05 PM | #5 |
I use the normal Rosin core solder, works 100% perfect.... scratch the end of the batteries really well, make a area for the solder to seat in to(like u would for JB Weld)(if u have ever used that) ... Like FrankyRizzo said get the batteries hot enough but dont over heat them... I will add, if the solder is not seating to the battery,STOP!!! scratch it more and re try Good luck |
09-14-2006, 03:08 PM | #6 | |
-Mike | |
10-07-2006, 03:22 PM | #7 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Sorry to dig up an old thread, but when building batteries, how should you wire them so that you don't increase the voltage, only the "mah"? Cheers 8-) |
10-08-2006, 02:13 AM | #8 | |
Quarry Creeper Join Date: Jul 2004 Location: 808
10-08-2006, 05:00 AM | #9 |
Like this?: Everybody loves paint Cheers 8-) |
