09-27-2006, 01:37 PM | #1 |
Newbie Join Date: Oct 2004 Location: Springtown
| Integy Pro 55T Lathe....What Gearing?
I just bought the Integy Pro 55T Lathe motor to put in my stock TLT. What gearing should I be running with it? I plan on going to 2.2 wheels and tires soon. Thanx.
09-27-2006, 02:22 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: Winston-Salem
I went with a 96T Spur and 13T pinion and it's probably overkill. Had to grind on the tranny plates quite a bit to let the motor sit close enough to mesh the pinion and spur. Not a lot of wheel speed, though. Depends on how you like to crawl, though.
09-27-2006, 11:46 PM | #3 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Need more wheel speed add another cell or two. |
09-28-2006, 12:14 AM | #4 |
RCC Addict Join Date: Apr 2005 Location: Seattle
I have the same question. I am running an 81 apur, the absolute biggest I can run with my setup. I am running the same motor as the thread starter, and Moabs. What pinion should I run with this combo? |
09-28-2006, 12:53 PM | #5 |
Rock Crawler Join Date: Jul 2005 Location: Central Coast
Advanex, are you running the stock TLT trans? I'm running a 55t Integy in a Rustler trans with a 87t spur with a 14t pinion with All-T's (these tires are taller than most 2.2's) and a standard 6 cell 3000mah pack. This gearing works great for me. Alright wheel speed, great low end. The 87t spur is the largest that will fit on the pede/rustler trans when using maxx shafts. The clearance is very tight, but it does fit. Bluemonster, you could try running a small pinion like the 14t. I think thats the smallest 48pitch pinion (not 100% sure). Last edited by wonder squirrel; 09-28-2006 at 01:01 PM. |
09-28-2006, 01:03 PM | #6 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
I like a 84 spur with a 15 pinion with Mashers and a 55 turn lathe. if i run a 65 turn i like to change pinion to a 13 tooth. sorry to a 14 not 13 tooth grrrrrr I got CRS can't remember Snit .
09-28-2006, 04:55 PM | #7 |
Yes, it is the stock tranny. I will be putting mashers or something to that effect on it pretty quick.
10-10-2006, 12:04 PM | #8 | |
10-10-2006, 04:46 PM | #9 |
Yeah, a lathe will take 12 volts, it's only a matter of what your speed control can handle. I ran a 9.6 pack of my buddies, simply amazing the difference.
10-10-2006, 05:17 PM | #10 | |
Quarry Creeper Join Date: Jan 2006 Location: Jonesboro, TN
