10-08-2006, 01:31 PM | #1 |
Newbie Join Date: Apr 2006 Location: uk
| nn chassis
hi, what are the best axels to use on the nn chassis eg clod,tlt......... thanks reg |
10-08-2006, 01:36 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
It's designed to use Clod axles.
10-08-2006, 01:59 PM | #3 |
thanks bender,iv looked at your chassis but not keen on the battery and esc being exsposed as im more likely to go rolling end over end till i get the hang of it,it does look very good reg |
10-08-2006, 03:12 PM | #4 |
Rock Crawler Join Date: Mar 2006 Location: Auburn, WA
What are you going to be using for axles, or is that still undecided?
10-09-2006, 10:33 AM | #5 |
mmmmmmmmmmmmmmmclod |
10-09-2006, 12:00 PM | #6 |
The NN is a great choice, I used it for my first crawler build, and found it to be a great chassis, and the instructions are really good too.
10-09-2006, 12:28 PM | #7 |
thanks tod1803,did you get just the chassis and everything else separate,or the whole kit |
10-09-2006, 01:57 PM | #8 | |
RCC Addict Join Date: Mar 2006 Location: MUSE, PA
10-09-2006, 07:20 PM | #9 |
I bought the complete chassis kit, not the RTR truck. I added axles I bought used. I would recommend going this way if it's your first build. The only major change I've made to the chassis is to add Agressor BTA steering on the front axle. I also don't like a bunch of stuff hanging out on the axles. I run the batteries in the chassis, and made a plate to mount the ESC and RX on. |
10-10-2006, 04:49 AM | #10 |
thanks chaps,sorry todd i ment to put not i think i will go as you said with the chassis, |
