Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: WB rules?
Old 10-09-2006, 12:06 AM   #1
nktrnl's Avatar
Default WB rules?
According to comp rules 12.5" WB is the limit.
But different people measure it different ways.
Which is the correct way, picture 1 or 2?
nktrnl is offline   Reply With Quote
Old 10-09-2006, 12:09 AM   #2
2006 2.2 National Champ
BENDER's Avatar
Wheelbase is measured to the center of the axles, so the 2nd pic looks right.
BENDER is offline   Reply With Quote
Old 10-09-2006, 12:27 AM   #3
AKA TOKEN
ColquittCustom405's Avatar
We do wheel nut to wheel nut.2nd picture.
ColquittCustom405 is online now   Reply With Quote
Old 10-09-2006, 12:47 PM   #4
nktrnl's Avatar
Thanks
Old 10-09-2006, 01:04 PM   #5
Axle nut to axle nut is wheelbase, but another easy method to measure wheelbase is from the font of the front tire to the front of the rear tire. If you are using deep offset wheels, this can be easier than guesstimating where the centerline of the axle is, and gives the same measurment.
todd1803 is offline   Reply With Quote
