Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: y harness for FULL TIME 4WS?
Old 10-11-2006, 03:31 PM   #1
~The Scale Shop~
STANG KILLA SS's Avatar
Default y harness for FULL TIME 4WS?
anyone doing this? how do you do full time 4WS? does someone sell a y harness? and do they need reversing like the motors?
i do not want another channel for the rear steer, i want full time 4 wheel steering. anyone done this?
Old 10-11-2006, 03:52 PM   #2
Are you talking about a Y splitter?
Thats actually what I'm using on my rig, but the only down side is you have to reverse one of the servos, so the arm is on the top instead of the buttom.. it's hard to see but yeah... I'm new at this RC thing, so there might be another way of doing it, I just don't know.. And this was the cheap way, the other way I was considering buying another reciever/controler but I didn't really wanna spend the money for a 3+ channel.
PaulEZK is offline   Reply With Quote
Old 10-11-2006, 04:01 PM   #3
Kamikaze's Avatar
This was the first post the search button came up with.
servo help ?
Imagine that
Kamikaze is offline   Reply With Quote
Old 10-11-2006, 04:46 PM   #4
Some companies make a reversing Y harness so one servo is opposite the other.
kjr2 is offline   Reply With Quote
Old 10-11-2006, 05:37 PM   #5
I lost my vendor privileges
i was running a servo reverser on my clod before i got a tq-3 no need for it now.
clodstall is offline   Reply With Quote
Old 10-11-2006, 05:44 PM   #6
~The Scale Shop~
link? info?
got to thinking about that reversing Y harness in the link in post above. does it reverse BOTH servos? that wouldnt work...
Old 10-11-2006, 06:01 PM   #7
No, It only reverses one servo.
ILoveRCRockCrawlin is offline   Reply With Quote
Old 10-11-2006, 11:10 PM   #8
http://www2.towerhobbies.com/cgi-bin/wti0093p?&C=MHD
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
I've been looking at doing something like this. except with a switch to engage a fail safe to keep the rear centered. still only uses a 2 channel radio, but have a little switch on the body somewhere that engages 4WS....
Numbchux is offline   Reply With Quote
Old 10-12-2006, 04:32 PM   #9
~The Scale Shop~
ok heres my question if you have your front servo on the drivers side, and the rear servo on the passenger side. do you still need a reversing Y harness?
Old 10-12-2006, 05:08 PM   #10
Yup, no matter what way you have it, you still need the reverser.. The only way to get around the reverser is to do what I did, and mount the turn link above the servo.. I'm gonna buy myself a reverser harness cause i hate having the link above the servo, seems like its gonna break or something.
Old 10-12-2006, 05:39 PM   #11
Rockpiledriver's Avatar
You should remove the rear servo alltogether and get used to driving it locked out. You won't be able to use it at comps, and if the rear moves you will be disqualified.
Rockpiledriver is offline   Reply With Quote
Old 10-12-2006, 05:53 PM   #12
I agree. Save money and remove or don't buy the servos, and if its clod based - don't stop at locking the diff - fill the whole rear axle with epoxy, silly putty, or hot glue. You'll have FULL TIME FRONT DIG....then you can Ebay the can motor for the rear and get yourself a Titan 550 - it's got more power because it is obviously bigger than a 540 stock clod motor. But-this might not work for a tlt axle.....I'd suggest removing the belt from the stock tranny and replace it with a Peatie tranny, if you've ever owned a TMAXX, you should have an extra. Replace the belt with a GD9000, run Revo turnbuckles, and a 3 cell pack - as long as you hard wired your transmitter - you won't need to steer
HannibalLecter is offline   Reply With Quote
Old 11-05-2006, 01:02 AM   #13
Picked one of these up on Ebay the other day, will it work?
Here's the link to the one I purchased:
http://cgi.ebay.com/ws/eBayISAPI.dll...7880&rd=1&rd=1
bluonyx is offline   Reply With Quote
Old 11-07-2006, 12:54 AM   #14
if they can just alter the three wires coming out of the servo then why can't you do it your self? If you already have a Y harness couldn't you just reverse the positive and negative and get the same effect?
viper7016 is offline   Reply With Quote
Old 12-17-2006, 04:26 PM   #15
FiremanJim's Avatar
yeah couldnt you just cut the wires and resolder them blk to white and white to blk
FiremanJim is offline   Reply With Quote
Old 12-17-2006, 04:27 PM   #16
FiremanJim's Avatar
I have a stock rockbuster and I have no room to put the arm where it swings from the top or else I would just do that
Old 12-17-2006, 04:55 PM   #17
Talking
Yes that wall work
Shane
Rockmuncher is offline   Reply With Quote
Old 12-17-2006, 05:14 PM   #18
FiremanJim's Avatar
except the dude on ebay only had one to sell and I need one also
Old 12-17-2006, 05:20 PM   #19
This will work perfect. It also has trim adjustment. I have the same one on all 3 of my rigs!
mr.maxx is offline   Reply With Quote
Old 12-17-2006, 05:33 PM   #20
Horizon hobby has them for $8.95:
http://www.horizonhobby.com/Products...ProdId=EXRA325
