| | #1 |
| Rock Stacker Join Date: Sep 2006 Location: Corning
| Use them or not. Are they must or not important? Also I have read that it might matter how a motor is wired as far a forward and reverse. Is there a wrong way and a right way? one way better then the other? Thanks for any info |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Mar 2005 Location: Saginaw
| A lot of people don't have any problems running thier motors without capacitors in crawlers. But they are cheap and it is an easy thing to do, so I say why not? Wiring your motor correctly is important if the motor is timed. But lathe motors are set at zero timing, so in that instance it dosen't matter - as long as you wire it so it spins the way you need it to (unless you have a radio that can reverse the throttle channel - then if it spins the wring way, you can just flip a switch). |
| | #3 |
| Thanks for that info. It helps a lot. I will use the capacitor then and I will just wire the motor up. I am using a traxxas controler form my revo and has the switch to flip if it si backwards. Thanks again |
| Thread Tools | |
| Display Modes | |
