11-11-2013, 08:27 PM | #1 |
Rock Stacker Join Date: Aug 2013 Location: Gallatin
| Wraith problem.
I have recently put together a wraith kit. I put it together and everything works. I noticed the other day the front driveshaft was hitting the top plastic link anyone know an quick fix. Lmk thanks
11-11-2013, 08:43 PM | #2 |
Newbie Join Date: Oct 2013 Location: SO-CAL
| Re: Wraith problem.
I noticed this as well when I put together my kit. but once I put the shocks on, it actually limits the travel so the shaft doesn't reach the link anymore. Does yours still rub with the shocks on.
11-11-2013, 08:46 PM | #3 |
| Re: Wraith problem.
Yeah it dose now. I'm trying to think how to fix it.
11-11-2013, 08:48 PM | #4 |
Rock Stacker Join Date: Dec 2009 Location: Calgary, AB, Canada
| Re: Wraith problem.
Are the upper links installed the correct way? Short side of bend on chassis side?
11-11-2013, 08:50 PM | #5 |
Quarry Creeper Join Date: Nov 2013 Location: Pittsburgh
| Re: Wraith problem.
Do you have the rubber stopper on the shock shaft? That should be just enough to limit the travel so that it does not hit. Also are the links in the right spots? The upper links have that bend to them so they shouldn't hit the driveshaft. But it the rig has to much travel than it will hit. I found that out when I put longer shocks on my wraith.
11-11-2013, 08:55 PM | #6 |
| Re: Wraith problem.
Yeah there installed right lol l
11-11-2013, 08:57 PM | #7 |
| Re: Wraith problem. |
11-11-2013, 10:06 PM | #8 |
| Re: Wraith problem.
Yeah I found the problem lol I had the wrong links up front. Thanks guys for the help. One more question the shock in the front when compressed it acts like it sticks when it's fully compressed and want release. ?
11-12-2013, 11:56 AM | #9 |
| Re: Wraith problem.
Take the shock apart. When you take the top cap off make sure the bladder in place and not sucked down into the shock. Inspect the piston to make sure that there isn't any flashing on the piston that is causing it to stick and that the piston travels easily up and down the shock body. Then refill it and test it. The XR-10 shock build video shows the build and fill process which works pretty well. The XR-10 has the same shocks as the Wraith. RC ADVENTURES - AXiAL XR10 ROCK CRAWLER - BUiLD SERiES - PT 3 - LiNKS, SHOCKS, SUSPENSiON - YouTube |
11-28-2013, 09:15 PM | #10 |
Pebble Pounder Join Date: Nov 2013 Location: tracy city
| Re: Wraith problem.
Kind of have the same problem with my driveshaft but its the rear it rubs the skid plate
Wraith problem. - Similar Threads | ||||
Wraith steering problem | MexicanMarauder | Axial Wraith | 18 | 06-23-2013 04:55 PM |
Wraith esc problem | uncle-speed | Axial Wraith | 11 | 10-28-2011 07:06 PM |
Wraith with VP Knuckles problem | craddock35 | Axial Wraith | 28 | 10-19-2011 11:45 PM |
wraith problem | karrfab | Axial Wraith | 3 | 08-31-2011 12:59 PM |
Problem with wraith esc. | Erbing | Electronics | 5 | 08-06-2011 06:36 PM |
