10-29-2006, 05:01 AM | #1 |
Quarry Creeper Join Date: Dec 2005 Location: United Kingdom
| Problem soldering wires to motor
I am trying to solder the power cables to an integy motor. The solder will not stick to the motor tabs where you connect the wires. The solder heats up and melts, but however it only just does stick. I am then able to slide the solder off the tab using my finger nail. There is then a yellow residue left on the tab. I have lightly sanded the tab and also cleaned it using turpentine substitute. My fingers have then not made contact with the tab. The solder I am using is a 5 core solder, made by a company called Ersin. It states on the tube the following. Savbit Alloy. % cores ersin flux, 5 core solder. Worlds finest solder for electrical and electronic joints. Seeing as I have purchased the best solder in the world [alledgedly] is it down to me having hands like cows tits and been too heavy handed or something. Any help will be appreciated. |
10-29-2006, 05:12 AM | #2 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
dont just lightly sand the tab.... take a file/dremel/knife/whatever and scuff it up real good....... put some flux on it(The plumbers flux ya get for plumbing/soldering pipes works great) put the iron on the tab and get it hot.... then add electrical solder do the same for the wire... add flux, heat, solder....... Then put both together, add heat and viola Sometimes i never even scuff up that motor tab and still never have a problem.. I just use your basic electrical solder from radio shack |
10-29-2006, 05:24 AM | #3 | |
I wanna be Dave Join Date: Jun 2005 Location: On the G-Train!!!!!
10-29-2006, 05:52 AM | #4 |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
it could be your soldering iron is dirty, get a sponge wet it, clean hot tip then once tip is clean "tin" it by adding solder and let it sit for about 15 seconds.solder on iron will be shiny.Then try to solder the wire after that. "If clean is iron, Stuck will be solder young Jedi" |
10-29-2006, 05:58 AM | #5 |
In My best Jedi. Thanks you me does. Thank you chaps. The dremel waqs the key I think. The iron was clean but I also gave it another clean. The job is done anyway. Thanks once again for the help. Return once more, will I. |
