01-21-2014, 05:56 AM | #1 |
Newbie Join Date: Dec 2013 Location: Sherwood park, Alberta
| Losing night crawler wheels won't turn
To start off the wheels do turn fine when powered up and running, but when the truck is not powered, if I grab a wheel and try to turn it they do not move. Usually on a non crawler truck the wheel on the opposite side will turn in the other direction. Is this normal for a crawler? Or losi specific. Or is something bound up in there?
01-21-2014, 06:04 AM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Glendale Az
| Re: Losing night crawler wheels won't turn
Worm drive axles will only turn when spun from the pinion....that's the beauty of worm gears.
01-21-2014, 06:11 AM | #3 |
Ah the worms, thank you.
01-21-2014, 06:16 AM | #4 |
Your next stop should be the losi comp/nightcrawler section to start learning how to maintain those pesky worm drive axles...... |
01-22-2014, 01:00 AM | #5 |
Not only do the worm drives prevent "accidental movement", but there's also the lack of a differential that prevents the opposite wheel from turning. Crawlers typically don't use differentials. |
Losing night crawler wheels won't turn - Similar Threads | ||||
losi night crawler wheels | Jwebb2.5rs | Tires and Wheels | 3 | 04-27-2011 08:55 PM |
