01-26-2014, 08:35 PM | #1 |
Quarry Creeper Join Date: May 2012 Location: Biloxi
| Loctite, loctite and... LOCTITE!!! I dont consider myself a "newbie" so much anymore but i sure did pull a rookie move. Just to keep you guys reading this from making the same mistake, ill share. Anytime your using machine screws, without a locknut, use loctite. Go buy some now if you dont have any so when the time comes, youll have it. I didnt have any and im impatient so i just figured i would check the screws every so often while im out playing. Nope. I forgot. Now i have myself a headache. the bottom screw on my knuckle came out and the knuckle folded over a little bit (aluminum chubs n knucks). Now the top screw is cracked and i know when i try and take it out, its going to break. And always remember, loctite. |
01-26-2014, 09:08 PM | #2 | |
RCC Addict Join Date: Jun 2008 Location: In the woods
| Re: Loctite, loctite and... Quote:
been there done that.lol that is why I always use locking acorn nuts if possible and always keep loctite in the hobby box. | |
01-26-2014, 09:12 PM | #3 |
Random side note about Locite. It tastes kinda sweet, the blue variety.
01-26-2014, 10:31 PM | #4 |
Rock Stacker Join Date: Oct 2012 Location: Canberra, Australia
| Re: Loctite, loctite and... |
01-26-2014, 11:03 PM | #5 | |
JUNKFOOT is my third shafty. You'd think I'da learned my lesson with the previous two, but no, lost half of the front driveshaft less than 5 minutes into it's first trail run. Results in this........... Video Last edited by Trubble; 01-26-2014 at 11:05 PM. Reason: Embed didn't work, have a link instead. | |
01-27-2014, 05:06 AM | #6 |
01-27-2014, 08:50 AM | #7 |
Newbie Join Date: Jan 2013 Location: SLT
Antifreeze is sweet to but i dont put it on hot dogs? Locktight will eat the varnish off wood, even if wiped right off. So try not to get it on the kitchen table...... |
01-27-2014, 09:28 AM | #8 |
Newbie Join Date: Jan 2014 Location: Houston TEXAS
I'm assuming BLUE is the variety of choice since it's "semi-permanent" right? Is there any application where you'd want to use the RED aka "permanent" or should it be avoided?
01-27-2014, 01:49 PM | #9 |
| Re: Loctite, loctite and... I watched a guy pull the cap off CA glue with his mouth and shoot a bunch of it in there. His mouth was dry and you know that stuff bonds instantly with skin. Oh it was hilarious but, he didn't think so.
01-27-2014, 02:10 PM | #10 | ||
Sounds like a good $10 challenge, for someone other than me. | ||
01-27-2014, 02:13 PM | #11 | |
I wanna be Dave Join Date: Aug 2007 Location: *
Generally RED Loctite isn't recommended for use on small fasteners such as M3 and 4-40, so don't use it. Go out and get a stick of this: Keep it in your tool box, it works great and won't leak. It looks like a large tube of ChapStick, maybe we can get Szczerba to try it out... | |
01-27-2014, 02:41 PM | #12 | |
01-27-2014, 05:23 PM | #13 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
This is the best thread locker for little screws....Factory Team Thread Locking Adhesive, blue: Team Associated - Champions By Design - Nitro and Electric RC Cars |
01-27-2014, 05:33 PM | #14 |
01-28-2014, 09:25 PM | #15 |
That loctite quickstix this is awesome! ive never seen such a thing. This stuff is expensive though. Is there a good alternative thats not $7 or more for a few drops?
01-29-2014, 10:45 AM | #16 |
Quarry Creeper Join Date: Dec 2013 Location: Pevely
Years ago , when I was a broke kid just getting into the hobby, I found loctite was out of my budget so my Dad suggested just using clear fingernail polish from the dollar store and it worked well. Now I have to have loctite in the garage or everything will vibrate off of my Harley.
01-29-2014, 12:01 PM | #17 |
Pebble Pounder Join Date: Nov 2013 Location: Bedford, Nova Scotia, Canada
I've read that blue threadlocker can harm plastics though. Is there a good one that is safe on plastic? And no, I do NOT USE THREADLOCKER ON METAL-TO-PLASTIC or PLASTIC-TO-PLASTIC connections. I'm just saying you can easily get threadlocker on plastic parts, even when using it on metal-to-metal connections. I have a CR-01, and anyone with one of thsoe can tell you that you have a million screws that need threadlocker.
01-31-2014, 10:41 AM | #18 |
Newbie Join Date: Jan 2014 Location: Mass
I use threadlock on all screws that go into metal I even use it on lock nuts...also use it on plastic when its a high stress point of the vehicle ie. shock towers, bulkheads,etc . and never had a problem with it hurting the plastic
01-31-2014, 12:37 PM | #19 |
Quarry Creeper Join Date: Dec 2013 Location: The Garden State, North of I-80
You may not notice it right away but Loctite will damage plastic over time, making them brittle, crack, etc. Take a look at their application spec sheet. I would not use Loctite on any plastic.
01-31-2014, 12:43 PM | #20 |
Loctite doesn't work so well for plastic anyway. Using either superglue or shoe goo has held screws into plastic for me.
Loctite, loctite and... - Similar Threads | ||||
Which loctite do you use????? | donhd04 | Tools, and Procedures | 22 | 08-31-2012 07:44 PM |
Loctite | Onebdgti | General Crawlers | 3 | 01-08-2012 05:57 PM |
Loctite ? | muddywaters | Axial Wraith | 8 | 10-04-2011 01:21 PM |
Loctite v2 | ripper7777777 | 2.2 Scale Rigs | 49 | 06-10-2009 09:42 PM |
loctite | andrewmp6 | Newbie General | 5 | 01-08-2007 07:36 PM |
