03-26-2015, 04:45 PM | #1 |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Vanquish scx10 axles or stock plastic axles?
Hello forums! I had question about axles! I'm making a chassis and thinking about upgrading. Should I get vp's scx10 alminuim axles or the stock plastic axles? Thanks Jacob |
03-26-2015, 06:21 PM | #2 |
Quarry Creeper Join Date: May 2014 Location: Burlington, ON Canada
| Re: Vanquish scx10 axles or stock plastic axles?
How much do you want to spend? Currie's will cost you $300+ and Axial's $25. Curries... RC4WD Trex... and all other scale axles |
03-26-2015, 06:53 PM | #3 | |
Pebble Pounder Join Date: Oct 2014 Location: bellville
| Re: Vanquish scx10 axles or stock plastic axles? Quote:
You read my mind with the link. | |
03-26-2015, 07:19 PM | #4 |
I would like to spend some money maybe around 150-200, but im on a little bit of tight budget. and I've seen plastic axles snap and take out a lot of stuff!
03-26-2015, 08:50 PM | #5 |
The green lettering in GodSpeed999's post is a link. You really need to left click it and read. You will find out how much you could spend.
03-27-2015, 07:27 AM | #6 |
Thanks! I have axles and all of the parts got got new gears a for the transmission. Should I invest in steel drive shafts? What upgrades should I invest in?
03-27-2015, 10:16 AM | #7 | |
If I just bought a new scx10 rtr. This is the list of upgrades I would do first and in this order. 1 CC BEC & water proof electronics 2 steel drive shaft 3 pinion gear (I like 18T on stock rig) 4 steel transmission gears 5 steering servo & steering linkage 6 tires & wheels (bead locks) 7 suspension linkage 8 what ever breaks next lol | |
03-27-2015, 01:22 PM | #8 |
OK thanks. I've got suspension links already, got metal drive shafts I have done the pinion gear, I have done wheels not tires. I like number 8! I have a water proofed esc and electronics. And the BEC is for what? Thanks for the list
03-27-2015, 02:13 PM | #9 |
my oldest set of axial axle housings lasted over 4 yrs. unless you going for the bling factor go with the stock housings
03-27-2015, 02:16 PM | #10 | |
Link below. Bec why is it a must????? | |
03-27-2015, 02:34 PM | #11 |
Plastic Axial housings with Beef Tubes.
03-27-2015, 04:26 PM | #12 |
Thanks for the link Ok Jonny I was going to do that anyway. Ok man, Thanks for the info guys much aprecite it. Thank you so much!!!!!!!!!! Last edited by THX_138; 12-13-2015 at 09:14 AM. Reason: Merge, posting minute apart |
03-27-2015, 09:40 PM | #13 |
| Re: Vanquish scx10 axles or stock plastic axles? |
Tags |
axles |
Vanquish scx10 axles or stock plastic axles? - Similar Threads | ||||
Vanquish SCX10 Currie Axles IN Stock | RPP Hobby | RPP Hobby | 2 | 03-26-2015 07:54 PM |
