02-05-2015, 09:55 AM | #1 |
Newbie Join Date: Jul 2012 Location: Eagle Creek
| Wheel weights?
Hey all, I've been running my SCX10 with the battery mounted over the front axle. It still seems too light in front. Would I benefit from adding wheel weight to the front end? And if so, what's the best way to do that? I was going to head to the fishing store and look for lead in lengths that I could wrap inside the tire. If I do that, do I put it against my rim, or stuff it between the inside of the tire and the foam? Lastly, how much should I initially try? Thanks for any suggestions!
02-05-2015, 10:15 AM | #2 |
| Re: Wheel weights?
These are the weights of choice to put around the wheel. They have a sticky backing tape and are segmented to conform around the wheel. I would start out about 2 oz per wheel. Great Planes Segmented Lead Weights 6 oz Also, changing the rear upper link geometry will increase front wheel traction. JC Auto Design - SCX10 Rear Upper Link Risers - Improved geometry ... |
02-05-2015, 12:02 PM | #3 |
Pebble Pounder Join Date: Jan 2014 Location: Knoxville
| Re: Wheel weights?
Wheel weights are an inexpensive way to increase front wheel traction, but they do add rotating weight. That means the motor has to work a little harder to turn the wheels over, and even harder to create wheel speed to get over stuff. Other ways to increase front end bite are: adding a steel bumper, heavier axle components, weight attached to the frame (but keep it as low on the chassis as possible). Good Luck.
02-05-2015, 06:05 PM | #4 | |
| Re: Wheel weights? Quote:
Thank you for that advice. I like the idea of steel bumpers as I'm ready to upgrade from the stock Dingo bumpers I have now. I will look for a set of those, or at least a front one. | |
02-05-2015, 06:07 PM | #5 | |
02-06-2015, 12:18 AM | #6 |
| Re: Wheel weights?
Just to make it clear: Wheel weights should be stuck to the rims, not to the tire.
02-06-2015, 01:22 AM | #7 |
RCC Addict Join Date: Oct 2012 Location: Norcal
| Re: Wheel weights?
Look into knuckle weights, better than wheel weights anyday!
02-06-2015, 01:28 AM | #8 |
Quarry Creeper Join Date: Jan 2011 Location: Perth, Western Australia, 6108
| Re: Wheel weights?
I use self adhesive LEAD wheel balance weights I get from a local tyre fitter. A good cheap option if you want wheel weights. Last edited by HyperMark; 02-06-2015 at 01:34 AM. |
02-06-2015, 04:35 AM | #9 |
| Re: Wheel weights? |
02-08-2015, 04:32 PM | #10 |
Quarry Creeper Join Date: Feb 2015 Location: burley
| Re: Wheel weights?
I know it's probably not the best way to do it but I take the foam out so there is more tire squish to grab rocks and I've got beadlock wheels so I put as much water in as I could and then tightened the bead lock and never had a problem again with traction or weight in the front end.
02-08-2015, 04:51 PM | #11 |
Quarry Creeper Join Date: May 2014 Location: Burlington, ON Canada
| Re: Wheel weights?
You fill your tires with water? |
02-08-2015, 05:00 PM | #12 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: Wheel weights?
Really??? Water |
02-08-2015, 07:32 PM | #13 |
| Re: Wheel weights?
Haha like I said it's prob not right in other people's eyes but yes I do. I run a service truck doing truck and farm tires and since some people use calcium in their tractor tires for more weight and traction that's why I decided to give it a shot and I can get the tire prob just shy of 75% full of water before I tighten down the bead lock and like I said it improved my traction and front end lift big time! ya I prob could'vE just grabbed some tape weights from the shop but I figured I could get more weight and adjust the weight more or less a lot easier.
02-08-2015, 11:03 PM | #14 |
| Re: Wheel weights?
I suspect the bead locks hold the water in ok but the rotating mass of water has got to be hard on your drive train and motor. I guess I'm not a big fan of weights in the wheels. It was a sad day when the rules committee decided that knuckle weights were outlawed. How do you keep the water in until you get the beadlocks bolted down??? |
02-09-2015, 09:01 AM | #15 |
| Re: Wheel weights?
well I started filling them only about half full cuz it started getting pretty warm pretty quick and once I started doing only half everything stopped heating up. As for fill them I bolt on the back bead lock and the kinda tilt the tire so it's almost laying down and then fill til it starts overflowing a little and then bolt the front bead lock down
02-09-2015, 09:03 AM | #16 |
| Re: Wheel weights?
And I got to thinking I have used some tape weights from our shop that you use on cars and pickups and put them on each side of the axle but I didn't get as good of results
02-09-2015, 10:42 AM | #17 | |
02-09-2015, 02:11 PM | #18 |
| Re: Wheel weights?
No I never really took time to weigh anything. I just did like I do in tractor tires and filled to the same level on both of them to the best I could. I don't have that crawler anymore but I am gonna be buying a honcho scx10 here very shortly if everything goes right and I'll make a video of it for you And weigh them too. I put it in the back tires too just for more weight
02-09-2015, 08:28 PM | #19 |
| Re: Wheel weights?
I bought a nice RC4WD steel front bumper tonight at my local hobby shop. Got to try it out in their indoor crawl space & beer pub. It seems to have helped some. And at any rate it looks nicer than the stock Axial bumper.
02-09-2015, 10:02 PM | #20 | |
Wheel weight in general is a bad thing for the drivetrain, if it hasn't been upgraded that is. I like the pendulum effect offered in a high centered situation with wheel weights, jerking the throttle and instant drag brake will wiggle the entire truck around. | |
Wheel weights? - Similar Threads | ||||
Wheel weights? | RCHuffer | U4RC | 4 | 03-31-2014 04:34 PM |
Knuckle Weights vs. Wheel Weights | Harvo | Tires and Wheels | 34 | 11-16-2011 01:15 PM |
wheel weights? who has them? | traxxas4fun | Tamiya XC/CC01 | 4 | 02-17-2010 02:12 PM |
wheel weights for 1.9s? | indianakrawler | Tires and Wheels | 14 | 11-07-2008 06:44 PM |
