Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: 2.2 honcho
Old 09-02-2015, 11:12 PM   #1
Default 2.2 honcho
I have put 2.2 bf Goodrich krawler ta and 90 mm gmade shocks on it. I am having the hardest time getting the right link kit to fix my binding issue. The angle up at the trans. Is horrible. Is there anyone with a honcho and similar mods. That has found a solution for this issue? Thanks please help getting expensive throwing parts at it
Bradley F250 honcho is offline   Reply With Quote
Old 09-03-2015, 01:42 AM   #2
Default Re: 2.2 honcho
sure yer installing the links properly ?
pictures would be helpful
TacoCrawler is offline   Reply With Quote
Old 09-05-2015, 10:35 PM   #3
Making true custom links with exact measurements on a 1/10 scale i used a 100-102mm Turnbuckles like this one http://www.amain.com/rc-cars/hot-bodies-4x100mm-turn-buckle-set-2-hbs67806/p86042.
and the rod ends of your choice (Traxxas 5347 to be exact). You can fine tune by less than 1/2mm if you wanted.
cmbscx10 is offline   Reply With Quote
Old 09-06-2015, 02:48 PM   #4
Get the axle pinion either pointed more up to the trans or closer to the same plane as the trans. As you're finding, the scx platform isn't really made for big tires unless some tinkering is done.
Meatwad is offline   Reply With Quote
Old 09-19-2015, 05:04 PM   #5
RcBros Burly Mud Truck Conversion | RcBros Hobbies
ussprinceton2004 is offline   Reply With Quote
2.2 honcho - Similar Threads
Non-honcho body for honcho roll cage question Jgreen76 Axial SCX-10 2 01-27-2015 11:41 PM
New guy, SCX10 Honcho RTR, a few questions about my Honcho dan188 Axial SCX-10 2 10-04-2013 09:43 AM
Honcho Body on an AX10 = Honcho Scrawler Sno Dawg Axial AX-10 Scorpion 6 04-05-2011 06:13 AM
