12-26-2015, 09:23 PM | #1 |
Newbie Join Date: Dec 2015 Location: Nashville
| Motor, esc hooking up: reverse and controller 2 questions
1st. I have a dynamite 55 turn motor, flysky gt2e controller and whatever receiver comes with it, and a wp 60afwd/rev brushed esc. I've got it all hooked up but I'm not sure how to go in reverse? I don't know how to attach a picture but the controller has St. Rev, which just makes it to where fwd is pushing the trigger and it turns the tires to the left(which doesn't make sense), it has a button that says bind( no idea), TH Rev, which I'm assuming says throttle reverse which also makes it where it pushes the trigger to move and it has steering trim, throttle trim, and St Dr which I don't know what that means. How do I get reverse in this or does it even have it? 2nd. I also have a sidewinder sv3 esc, an integy 35t motor, and the above controller etc. And I'm using a reaction 4000mah lipo battery right now. I'm not sure how to hook this up at all. I can soder it but I'm not sure what to hook up. Does someone have a diagram or something that I can use to hook it up? The esc has 3 holes which I guess is for the motor but I can't tell what hooks up to what. |
12-26-2015, 09:43 PM | #2 |
Quarry Creeper Join Date: Jun 2015 Location: Athol, Massachusetts
| Re: Motor, esc hooking up: reverse and controller 2 questions
On the sidewinder the two outer holes are used for brushed motors it don't matter what way you put them . You can change them around if it's backwards. The middle hole is only used for brushless motor.
12-26-2015, 09:44 PM | #3 |
Thanks I didn't know that. Do I just leave the center on alone? Or do I need to cap it?
12-26-2015, 09:46 PM | #4 | |||
Newbie Join Date: Sep 2015 Location: Midwest
12-26-2015, 10:03 PM | #5 |
Thank y'all! Here's a picture of the motor. Where do I connect the wires to? http://i1379.photobucket.com/albums/...psfqouapsz.jpg Alright I'll look for it. It didn't come with instructions so I'm just guessing haha Now I just need to get to work! Last edited by THX_138; 01-01-2016 at 08:25 PM. |
12-26-2015, 10:37 PM | #6 | |
| Re: Motor, esc hooking up: reverse and controller 2 questions Quote:
Motor, esc hooking up: reverse and controller 2 questions - Similar Threads | ||||
hooking up motor | Fanfor88 | Electronics | 5 | 04-17-2012 10:47 AM |
micro esc with reverse for brushed motor??? | S3K7 | Losi Micro-Rock Crawler | 20 | 03-29-2010 01:22 PM |
hooking up motor to my ESC | Martin B. | Electronics | 3 | 03-17-2009 12:04 PM |
couple questions after hooking up cc bec | madmaxxed | Electronics | 1 | 04-10-2008 07:10 PM |
