01-09-2007, 01:09 PM | #1 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
| help with low budget
ok i was wondering if i buy a tlt and a custom chassis and electronics etc etc could i use the stock gears because im not going to be doing anything to extrme probably climbing a brick or so but if i do something bit more hard core then i will change it so my question is can i use the stock gears and motors for a little mess about truck? and yes ive tried searching but when you put in tlt you get every tlt in the tlt bit!
01-09-2007, 02:10 PM | #2 |
RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
you can do whatever makes you happy my suggestion: get the TLT kit... save the money on the custom chassis and put it into a pede or r2 trans.. then modify the stock tlt plates and extend the wheelbase. btw: the tlt kit does not come with motor. |
01-09-2007, 03:02 PM | #3 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
The reason no one uses the stock centre transimission is because it is belt-driven and tends to slip under rock crawling loads, not because of the gearing. Good luck with your search. |
01-10-2007, 05:05 AM | #4 |
yer i know about the transmission i was thinking about the diffs or is that a completely stupid newb question?
01-10-2007, 03:14 PM | #5 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
They don't make different gear ratios for tlt axles...................yet
01-10-2007, 03:49 PM | #6 | |
