01-10-2007, 03:43 PM | #1 |
Newbie Join Date: Dec 2006 Location: USA
| chassis twist
are any of you guys having this problem when you hit the throttle it leans hard do to torque of motor can take some of it out with spring tension but then articulation suffers drasticaly rite now runnig stock motor will or does a lathe motor help with less top end thanks need suggestions mike |
01-10-2007, 04:23 PM | #2 |
I wanna be Dave Join Date: Sep 2004
a lathe motor will have more torque so that will not help. some use a stiffer shock spring and or oil on the left rear.
