11-26-2017, 10:09 PM | #1 |
Newbie Join Date: Nov 2017 Location: Salinas
| New build new questions
This is my first crawler, first scratch build. Has anyone ever had any dealings with Xtra speed axle housings? Found them on Fleabay for $20 each, are they a waste of $20 or will they do for stock replacements (since I don't have stockers to replace) Also never had a crawler before so do I want lockers (spools front/rear) or do I need a locker up front and an open diff out back (or visa versa). Thanks for any help, things sure have changed since I built my ESP chassis monster truck |
11-28-2017, 05:32 PM | #2 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: New build new questions
You would better buy New Original Axial axles, save your time and money https://www.ebay.com/itm/Axial-Updat....c100011.m1850 Yes, you would need spool, bevel and ring gears, axles drive shaft, bearing, CVD etc... Last edited by Teng; 11-28-2017 at 05:35 PM. |
11-28-2017, 06:58 PM | #3 | |
| Re: New build new questions Quote:
When I read new build I just assume you've got a new kit. The Wraith comes locked in front and rear, generally if you're crawling you want it fully locked, anyway I dont think they even make an open diff for these. I don't know that I'd recommend ditching the stock axle housings yet. I did when my LHS recommended it for going brushless and regret it. The main things in need of attention with the axles are the lockouts in the rear, they mount with 2 tiny screw which thread into the axle housing, these never stay tight and are usually lost pretty quickly. VP and likely others make a nicer "clamping" style lockout that always stays tight, look here. The front axles have the same issue where the C-hubs mount, VP has another pricey solution for the C-hubs. | |
11-28-2017, 07:45 PM | #4 |
I only have a frame, looked at a lot of threads and a lot of pictures, figured I'd probably replace this, replace that and end up with just the original frame with a wheelbarrow full of trick bits replacing everything else so I just found a frame cheap and I'm starting there(my ESP Clod only has the axle housings remaining). They do show an open diff gear set (probably off another model using the same internals) and RC4WD offers an open diff gear set, not knowing anything about crawlers I didn't know if I needed an open diff or a spool type, figuring this thing wasn't going to be seeing any high speed runs I was assuming spool was the way to go but I figured I should check in with the experts. Thanks for the help, learning something new every day |
11-28-2017, 07:49 PM | #5 |
If you don't have any axles at all, best bet is either the Dlux Fab axles - which are stock but modified for a larger bearing : Dlux Fab or for the rear only, the SSD HD D60 centered-pumpkin - which also uses the larger bearing and comes with the centered axles : SSD RC HD D60 Centered Rear Axle for Wraith SMT10 Yeti Save your money for lockers, front universals, steering knuckles, c-hubs, lockouts, steering links, servo horn, servo mount, and if you want 'em - metal diff housing covers and beef tubes.... (whew!) Plastic axle housings and pumpkins slide much better over obstacles. Save the metal for where the strength is needed. |
11-28-2017, 08:09 PM | #6 |
That seems like pretty solid advice, I can see where a crawler would probably be dragging bits on a pretty regular basis. I really like that centered rear axle.
11-29-2017, 08:29 AM | #7 |
Pebble Pounder Join Date: Feb 2016 Location: Shelby
For ar60 housings, either stock or dlux Fab you need to run beef tubes. Either run the real deal from beeftubes.com or the cheaper knockoffs. They give weight down low, reinforce the axel tubes and give you something solid to screw lockouts and chubs to.
11-29-2017, 08:42 AM | #8 |
Also good to know, I'll pick up a set when I make the "final" decision on axle housings Sent from my XT1080 using Tapatalk |
11-29-2017, 02:04 PM | #9 | |
I've been running the AX10 with the metal Xtra speed housings for several weeks now and have not had to re-tighten or snug C-hubs or lockouts since. For the money, the Xtra speed housings are a good value. Just my 2 pennies. | |
11-29-2017, 03:47 PM | #10 |
I have the boom racing axle housings the same as th3 xtra peed there awsome they slide over rocks better than the aluminum and are stronger than the plastic and realy plant the rig on the rocks but there are heavy another + the gears cant deflect like they do on the plastic housings if you plan on running big power metal axles are a must if your gona run a 540 or 550 sized can motor you should be ok with plastic and beef tubes i did the big bearing mod on my rear it was easy enuff i run a thrust bearing up front and its working well but they wouldent work in the rear for some reason the machining was a bit off hence the big bearing mod instead they may take a bit of love to get everything to fit right but for the price those axlels are a great deal just be prepared to do the fit and finnish your self
11-30-2017, 05:38 AM | #11 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
Here is a link to my review of the xtra speed axles for the SCX10. http://www.rccrawler.com/forum/redca...ml#post5771402 |
11-30-2017, 08:12 AM | #12 |
Well they seem to be more trouble than they're worth but for the price I ordered a pair to look at. I really like it when stuff just bolts together like it's supposed to, when I start "massaging" bits to get them to fit is when I start breaking things Sent from my XT1080 using Tapatalk |
11-30-2017, 08:28 AM | #13 |
I have the ar60 versions and the scx10 versions well worth the money
11-30-2017, 11:53 AM | #14 | |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
Sent from my SM-N920V using Tapatalk | |
12-01-2017, 12:11 PM | #15 |
Also, what's the consensus on shocks for the Wraith chassis, I've been looking at the King shocks because they have that "real shock" look, I'm in between those and the Gmade XD shocks. Anyone have an opinion? Sent from my XT1080 using Tapatalk |
12-23-2017, 03:50 PM | #16 |
Well here's where I started; Picked up a frame off Fleabay Replaced all these bits with aluminum bits (because I'm a sucker for billet) Added some of these And pieced all this together since I started with none of it DLux front housing with SSD Chubs and STRC servo mount, SSD centered rear housing, GPM upper and lower arms attached to VP arm/shock mounts all on a O.E. Axial skid |
12-23-2017, 03:52 PM | #17 |
Still undecided on shocks but I'm leaning towards the GMade reservoir shocks Also up in the air as to axle ratio, any opinions? |
12-24-2017, 10:14 AM | #18 |
| Re: New build new questions Ud (lowest ratio) gears in rear, and hd, or Od gears up front. Depends on how much trail running and rock crawling you plan on doing.
12-24-2017, 11:47 AM | #19 |
I imagine it's going to be more of a general "basher" than anything, some rocks, some trails and river beds
New build new questions - Similar Threads | ||||
want to do a build but have a few questions. | kpla51 | Axial SCX-10 | 9 | 09-14-2014 12:10 PM |
jk build questions | zaid7 | Axial SCX-10 | 1 | 09-19-2013 01:41 AM |
Next build,got some questions | jhtoy | Axial SCX-10 | 0 | 11-26-2012 10:13 AM |
new build questions | skate | General Scale Talk | 1 | 09-15-2008 05:24 PM |
new build/first build lots of questions | the kid | Tamiya Clod Buster | 4 | 01-31-2007 03:05 AM |
