11-27-2018, 01:16 PM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| How do you prefer to run it ?
Your spur gear , fully locked or just a lil slip. I was out testing the new HH motor and all metal ebay transmission on the rocks , got caught up, spur spun, i reversed to get out of the jam/bind , i guess it help , not breaking nothing was a good sign. LOL. I do know slipping helps the drive train, but its a crawler not a stampede. So is it better with a lil slip or it really doesn't matter with crawlers ? |
11-27-2018, 01:21 PM | #2 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: How do you prefer to run it ?
I pretty much only trail, I leave a little slip in my bomber with stock driveshafts Sent from my SM-G960W using Tapatalk |
11-27-2018, 01:28 PM | #3 |
Fully locked at all times. I'm in control of the throttle so breakage is my fault if it happend.
11-27-2018, 01:43 PM | #4 |
RCC Addict Join Date: Nov 2010 Location: England
Locked up. I just find slippers to be a bit random. Throttle control is all I use. If the truck won't move, I ease off, figure out why and if needed pick the truck up. I ripped a tire once on a root stub and ruined my day. That won't happen again. (Hopefully).
11-27-2018, 02:07 PM | #5 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
Locked. Like M1tch said its clear when the truck is bound up. On my race bomber its locked out too, but I run plastic WBHD shafts as my fail point. Slipper pads do wear out and trying to crawl with a slipping trans is no fun, so I avoid that issue all together. |
11-27-2018, 03:08 PM | #6 |
RCC Addict Join Date: Sep 2015 Location: Australia
I share mine with children, so my slippers are set up to slip, kids have no throttle control!
11-27-2018, 03:19 PM | #7 |
Quarry Creeper Join Date: Jun 2016 Location: Grand Rapids
No slip for me.
11-27-2018, 03:40 PM | #8 |
Quarry Creeper Join Date: Jan 2008 Location: Eagle Mountain, Utah
Slippers are good for go fast trucks, but I wouldn't want any slipping on a crawler.
11-27-2018, 04:39 PM | #9 |
I've had good luck with tightening them down all the way and backing it off a half turn or so. But I do like them to be able to slip if I get really bound up it gives, I think I can count the number of times they've slipped on one hand. I also use throttle control and my noggin to make sure its not bound up but I see no reason to not have it as a backup just in case unless its just giving you trouble (slipping when not wanted regardless of adjustment). Though now that I think about it I think the only slipper I ever had issues with was on the Axial Wraith after going brushless, the slipper pad came unglued and no amount of tightening helped (of coarse). Last edited by HumboldtEF; 11-27-2018 at 06:33 PM. |
11-27-2018, 05:29 PM | #10 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
I like it to slip. You just need to find that sweet spot where it will slip before your axles snap, but doesn't slip during normal crawling.
11-28-2018, 04:22 AM | #11 |
100% Locked with Slipper Eliminator. Put that power to the ground and use your head in a bind.
How do you prefer to run it ? - Similar Threads | ||||
Which do you prefer ? | Frank211 | Newbie General | 18 | 07-27-2018 04:43 PM |
Which do you prefer ? | Frank211 | Newbie General | 14 | 12-01-2017 10:47 AM |
Which do you Prefer for G6...C2 or C3 | photocycler | General Scale Talk | 1 | 03-06-2015 03:08 PM |
what esc does everybody prefer and run? | dabeav | Newbie General | 13 | 03-16-2011 11:47 AM |
what do you prefer? | ILoveRCRockCrawlin | Chit Chat | 12 | 04-29-2005 11:02 AM |
