01-18-2019, 04:08 PM | #1 |
Newbie Join Date: Feb 2014 Location: Central
| Shock oil wt
What shock oil weights do most people run? And do you run the same wt oils on the front and back shocks?
01-18-2019, 04:14 PM | #2 |
| Re: Shock oil wt
Depends on the truck, terrain, driving style and personal preference. Personally, I run 15wt in the summer and 10wt in the winter on my TRX4s. But there is more to it than just oil weight. I also run softer springs and around 50% droop. You need to try different weight shock oils and see which you prefer.
01-18-2019, 04:18 PM | #3 |
RCC Addict Join Date: Mar 2018 Location: Ocala, Florida, USA
| Re: Shock oil wt
I run 15wt in my Trx-4 shocks front and rear at about 40% droop. Stock the Trx-4 has 30wt. But I didn't like how slow the shocks reacted with it in them. I posted a video comparing the 2 not to long ago. https://www.youtube.com/watch?v=BE4zu54tOvk |
01-21-2019, 11:01 AM | #4 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
| Re: Shock oil wt
I typically run 30-40, sometimes as high as 60. Often it's the same weight front/rear but sometimes I'll go a little lighter in the rear. sometimes it's lighter in the front though too. There's no black & white answer bu that should point you in the right direction to do your own tuning. |
01-21-2019, 12:12 PM | #5 |
| Re: Shock oil wt
For a crawler (XR-10), I like running 60wt all of the way around. For my scale rigs, 30wt seem to work for me.
01-21-2019, 01:11 PM | #6 |
Rock Crawler Join Date: Dec 2018 Location: Ontario, Canada
| Re: Shock oil wt
I've seen videos of trucks running no shock oil in crawlers. For crawling, it looked pretty realistic to me. Anybody try that?
01-21-2019, 01:18 PM | #7 | |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Shock oil wt Quote:
I run 10-20wt usually. I feel like the trx4 shocks do better with a light oil myself but it’s all preference and application specific. Get a few options in a range and see what you like the most. | |
01-21-2019, 01:50 PM | #8 | |
And, several of the guys I run with deliberately run no oil because they're too lazy to fix their leaky shocks. Last edited by QuesoDelDiablo; 01-21-2019 at 01:52 PM. | |
01-21-2019, 02:56 PM | #9 | |
That's the direction I'm heading. I've noticed some leaking from my shocks, and really don't feel like taking them apart, unless the leaking yields unsatisfactory performance. | |
01-22-2019, 08:38 AM | #10 |
| Re: Shock oil wt In all honesty, for 90% of what we do with these trucks shock damping doesn't make a noticeable difference to handling..
01-22-2019, 08:57 AM | #11 | |
RCC Addict Join Date: Sep 2017 Location: The OC
^^This. For slow speed it doesn't make much difference. I will say though, a couple of years ago the vaterra piston holes were blocked by the retainer clip, so drilling them out and changing oil improved (reduced) damping action. The downside is it made torque-twist worse. I run 25 or 30wt, whatever happens to be handy. The main thing is to keep them topped up if they leak. So far my experience is they all eventually do, plastic, alloy, any brand. Maybe I'll try the slime thing - not holding my breath. | |
01-22-2019, 09:22 AM | #12 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
I would disagree with that statement. If you are talking about go fast type of handling, yes we don't do that at a rate where it is noticeable. But if we are discussing those times where we are bouncing over a series of obstacles or when we are applying throttle to get over one, you know the situation not much forward motion, but a decent amount of lateral, I think it is very important to have the damping set up to be predicable. I certainly don't want my wheels to drop into a crack that I am trying to float over. For the most part I find 30-60wt helpful to slow the rate(speed) in which the wheel descends. Sometimes a little extra time makes the difference in a tire dropping in the hole and the front edge catching the hole and pulling out of it. And honestly the difference between your really good competitive scale guys and the rest of us is good shock set up. I know I struggle with it all the time. I know a lot of people compensate for poor shock set up by changing driving style, I know I do, but when you have a set of gates or even just have getting over a set obstetrical as a goal dampening makes or breaks you. Unfortunately this is something very hard to learn on the internet, I certainly wish I was better at it. | |
01-22-2019, 10:13 AM | #13 |
Quarry Creeper Join Date: Jun 2008 Location: Central KY
| Re: Shock oil wt I legit lol'd at this! Personally I run 30 or 45 weight in most of my rigs, although I may go lighter with my kids SCX10 running TRX shocks as it's a pretty light rig and 30 weight oil in those seems to be pretty slow on damping. I will say that as a continuation of what most are suggesting in this thread that damping doesn't make as big of a difference in slow speed crawlers, I would probably run thinner oil in general to make them work a bit faster if anything when making transitions and higher speed running. Stiffer shocks make the rig pretty bouncy with the tires and foams we typically run.
01-22-2019, 12:38 PM | #14 |
| Re: Shock oil wt
So...we have fast-shock fans and slow-shock fans. I guess OP will never really know... |
01-22-2019, 01:47 PM | #15 |
| Re: Shock oil wt |
01-22-2019, 02:31 PM | #16 |
| Re: Shock oil wt |
01-22-2019, 02:33 PM | #17 |
| Re: Shock oil wt |
01-22-2019, 09:01 PM | #18 |
| Re: Shock oil wt
Put in a specific fluid, what comes stock, then change it to your liking.
10-02-2019, 11:21 AM | #19 | |
I wanna be Dave Join Date: Sep 2019 Location: US
1) Shock cap improperly screwed on, or not tight enough. 2) Bottom cap improperly screwed on, or not tight enough. 3) Bleeder screw (if using "bleeder" cap) improperly screwed in, or not tight enough. 4) Diaphragm missing, or needs to be replaced (if using diaphragm, as opposed to bleeder cap). 5) X-rings (inside bottom cap) missing, or needs to be replaced. These are not the only causes of leaking shocks...but is guess they are probably the cause of 95+% of leaks, and are all preventable, it very easily fixed. ~ More peace, love, laughter, & kindness would make the world a MUCH better place | |
Shock oil wt - Similar Threads | ||||
motor oil as a shock oil? | Mr.JayDeeM | General Crawlers | 10 | 09-02-2012 10:59 PM |
Shock oil and shock spring help | entropy | General Crawlers | 10 | 01-29-2011 08:40 AM |
The right shock oil? | quadimus | Losi Mini-Rock Crawler | 7 | 08-13-2010 06:31 PM |
best shock oil and gear oil | j4k3 | Axial SCX-10 | 2 | 07-26-2010 12:48 PM |
Shock OIl | Flash | General Crawlers | 5 | 03-27-2008 02:02 PM |
