05-16-2019, 09:51 PM | #1 |
Rock Stacker Join Date: Apr 2019 Location: Olympia
| Newb mistake... battery hooked up backwards... did I fry ESC?
This relates to a Traxxas ESC in the TRX4 Sport. So... I was in a hurry and not paying attention when putting the banana plugs into the battery that was in my truck. Usually I disconnect at the Deans, but for some reason I yanked the plugs from the battery last time. So radio was on, but ESC was off. Once I plugged in the wires I heard a brief zzzz sound, Immediately I pulled the wire and then put them back the right way. With the ESC on I have servo control, but nothing to the motor. The light blinks on the ESC in FWD or REV, but nothing. I hooked up a different Traxxas motor from a Slash using the standard connectors and it didn't turn either. I also went through the calibration process to eliminate that variable and it is the same. result So.... I guess its time to buy that HW WP1080 esc. Now I just wish I had ordered it Monday when I was considering replacing the stock one. This is probably not a warranty thing since it was my fault? Any other things to try to see if the ESC is shot? |
05-17-2019, 12:28 AM | #2 | |
Gold Star Baby! Join Date: Dec 2017 Location: Las Vegas
| Re: Newb mistake... battery hooked up backwards... did I fry ESC? Quote:
You have the right answer with the 1080. | |
05-17-2019, 03:21 AM | #3 |
you just discribed every traxxass esc ive ever used plug them in and then ssssssss poof yay traxxass |
05-17-2019, 07:35 AM | #4 |
So it was fate... I needed that push over the ledge to actually hit buy....
Newb mistake... battery hooked up backwards... did I fry ESC? - Similar Threads | ||||
Hooked battery up backwards | EthanOsborne | Axial Yeti | 10 | 07-13-2016 07:44 AM |
Newb. needs motor/esc and battery advice for 10Lb Trail Honcho | KellyC | Newbie General | 4 | 04-11-2016 06:20 PM |
Did I make a mistake buying the AX-10 Scorp or am I just a newb?? | PoweredHobbies.com | Axial AX-10 Scorpion | 109 | 05-19-2011 03:54 PM |
Newb Question LRP ESC/Battery | seawolf9er | Electronics | 1 | 03-27-2011 08:23 AM |
is the battery gonna fry it? | kawicrazed_125_05 | General Crawlers | 2 | 11-18-2006 01:02 PM |
