10-12-2019, 12:44 PM | #1 |
Rock Stacker Join Date: Dec 2009 Location: Everett
| SCX10 II electronics
Hey guys! Been out of RC for about a decade. A recent trip to Moab has me wanting to build a SCX10 II. Wanting to do a kit because it will keep me occupied through the long Seattle winter. From what I remember Spektrum was top choice for radio and receiver so I’ll probably stay in that direction unless otherwise convinced. Im just lost on what to do for any of the other electronics. I tend to stick with higher end over budget but any advice would be great thanks.
10-12-2019, 01:15 PM | #2 |
| Re: SCX10 II electronics
If you want to go brushless, Holmes Hobbies Puller Pro 2700kv or a similar Tekin or Castle Slate series motor, plus either a Castle Mamba X or a Tekin RX4 ESC. Servos are wide open - you can easily spend $100+ on a top-notch servo - Holmes, ProModeler, Savox 2290, or a Tekin. This all can get very expensive very quickly! However, crawlers do EXTREMELY well on relatively inexpensive brushed setups... So, at least to start off I'd recommend you pick up a HobbyWing 1080 ESC, Holmes Trailmaster or Crawlmaster Sport motor, Amazon DS3218 servo. That last combo will cost you less than $80 all told! And many of us are running it in the SCX10, the Vaterra Ascender, the Traxxas TRX-4, and the Element Enduro with fantastic results. Decide how much you like crawling, and have the ability to pick up a second vehicle with the savings... A very useful site for picking motors: https://holmeshobbies.com/motor-recommendations |
10-12-2019, 04:15 PM | #3 |
That’s good info! Thank you. I also just want to jump straight into LiPo batts. Any recommendations on good battery brands and a solid charger that won’t catch my house on fire? Also what’s the best battery connectors?
10-12-2019, 09:10 PM | #4 |
Everyone has their own favorite LiPo... I will say I went out today and ran through 2 of my SMC 3S LiPo hardpacks in my Enduro - and they are a few years old - Perfectly fine for my use. Same with chargers - there are many newer tech chargers out there, but I am cruising along with a 3+ year-old Dynamite Passport Ultra. As far as connectors go - do yourself a favor and try to start off using XT60 connectors - super convenient, easy to solder, easy to connect and disconnect - so easy you could do it in the dark. That way you don't end up having to go through your older gear and converting at some point... Although adaptors are easy to find - I confess I still have some stuff using Deans, and just use an adaptor for now - one of these days I'll switch completely over! |
10-13-2019, 01:41 PM | #5 |
Thanks again for the info, you have been quite helpful. I bought the SCX10 raw builders kit today and started building the axles. Any advice on how much grease to apply on the R&P. Couldn’t really find photos or YouTube videos of people greasing these.
10-13-2019, 04:01 PM | #6 |
Pebble Pounder Join Date: Jun 2018 Location: New Zealand
All good advice though I would look at the DSSERVO RDS3235 Servo. Much better specs than the 3218 and only a few dollars more. 1080 ESC and HH motors is a great combo Edit: Link to said servo https://tinyurl.com/y3qsudo9 Last edited by nzrc; 10-13-2019 at 04:18 PM. |
10-13-2019, 07:32 PM | #7 | |
| Re: SCX10 II electronics Quote:
I have run the first 2 and not yet installed the latter 2. Since the first worked great on 4.19" tires and the second on 4.6" tires (Ascender and Enduro), I am expecting good things of the other two... | |
10-14-2019, 08:53 AM | #8 |
More good info to feed my research. I think I’m just going to spend the money on a savox 2290. I’ve read that a few people have had issues with getting the servo and horn to live in the stock location on the 10.2 so I might go one step ahead with the samix servo relocation bracket
10-14-2019, 05:35 PM | #9 | |
I think ~400 oz-in is enough for most crawlers | |
SCX10 II electronics - Similar Threads | ||||
Scx10 ii electronics help | SerpentCT4S | Newbie General | 26 | 10-06-2016 05:33 PM |
scx10 electronics.... | davis | Newbie General | 1 | 01-23-2011 09:05 AM |
SCX10 Electronics | landy-ross | Newbie General | 14 | 05-12-2009 02:46 PM |
