02-19-2007, 05:30 PM | #1 |
Pebble Pounder Join Date: Feb 2007 Location: Woonsocket
| tlt,txt, clod
Just getting into crawling and would like to know where to start. I have a new bright rock crawler now but i would like to up grade my rig. So what is the difference between tlt,txt, and clods? I know clods have two motors but what are the pros and cons of each? I don't want to spend a crap load of money, working on a low budget for this. I hear to start with a tlt but i don't like the clearance they give. Thank you
02-19-2007, 08:29 PM | #2 |
Rock Crawler Join Date: Sep 2006 Location: Esco.
| Then get a clod. Try researchin a little and you will find the info you need, this site gives you everything just gotta look. |
02-19-2007, 08:38 PM | #3 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
There's plenty of low budget builds, actually... What your budget is will more give you an idea of what you can build for your purpose... Do some reading on some of the builds in the different areas and you can gain a better idea from there... |
02-19-2007, 09:38 PM | #4 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
A TLT can have plenty of clearance, just depends on the tires. A TLT is a shaft driven single motor rig most of the time. They tend to look more scale and your crawling area options are better. A clod based rig is HUGE and tends to just run over everything. Aren't very scale and cost more. With a NN chassis and a stock clodbuster your at an easy $400. A TLT is like $70 and most decent TLT chassis will run around $100 some more some less, depends on your look. Figure a minimum of around $500 for a decent rig, built with new parts. If you scrouge and get some used stuff and run stock pieces for a bit it can be built for less. Buy a built crawler someone is selling for a few hundred and your basically coming out ahead most of the time. But for me building it was the most fun. Mostly it comes down to terrain and builders preference and ultimately $$ |
02-19-2007, 10:52 PM | #5 |
HANDSDOWN!,build the TLT.
02-20-2007, 09:09 PM | #6 |
RCC Addict Join Date: Feb 2005 Location: Vancouver Island B.C.
Without question, build a TLT. They can be alot more capable than you might think, and on a whole different level than a newbright. Clearance is only one piece of the puzzle, and they are definitely the most affordable.
02-22-2007, 10:29 AM | #7 |
thanks a lot guys for the info and input. I am going to go with a TLT. I would rather build one than to by one so i can understand how it works better and if something gos wrong i will better be able to fix it. As far as reading and looking on the sites for info, i have been for about 8 hours a day for a week. there is just so much out there. It take me for ever to pick somthing out. I'm very fussy. I dont' think i can go much longer with the new bright. I ordered a TLT-1 rock buster. i'll use that for a bit and add bits and peices when i can. I want to go witha scale look for sure. What type of chassis am i looking at for this kind of build? And just to make sure i have it right i'm pretty much only going to be using the axles on this right everything else isn't worth much. Well, unless i use bits and peices here and there. Thanks guys
02-24-2007, 05:08 AM | #8 | |
