06-27-2022, 12:32 AM | #1 |
Newbie Join Date: Feb 2022 Location: Australia
| Is this a Dumb Question
I am building my second Injora Cherokee "Logic says if you have 2 real Cherokee's you need 2 RC ones" I have noticed that the shocks are upside down? Is there a reason for this? On a real car they are normally the other way with the shaft on top pushing the piston down. Can I flip the rc shocks I just dont like the look |
06-27-2022, 01:53 AM | #2 |
Rock Crawler Join Date: Apr 2015 Location: San Marcos
| Re: Is this a Dumb Question
You certainly can flip them, and many do. The weight of the shock is in the body, especially as that's where the oil is. Putting that weight lower down instead of higher up is certainly an advantage. I can't think of any reason not to flip your shocks upside down. Maybe if your upper caps are really leaky, but if that's true, your shocks are going to leak either way. |
06-27-2022, 07:06 AM | #3 |
shocks usualy have the shaft.coming out from the bottom of the shock body now struts have the shaft coming out the top dose it matter no can you flip shocks so the shaft comes out the top yes can you flip a strut well in theory yes but it will only bolt on oneway most shocks have different eyes top and bottom so you can only install the shock 1 way ive never seen a inverted shock from the factory but i know a guy who builds struts using of the shelf shocks and invets them to use as a strut and they work just fine on the rc shocks just make sure your fluid is toped off all the way to the top or you will have a dead spot in the shock |
06-27-2022, 09:31 PM | #4 |
RCC Addict Join Date: Feb 2017 Location: Surprise
Hey... One, there's is no dumb question when you're new to a hobby, CUZ you're learning, 2 you'll get to the point where you'll end up doing what you like in this hobby! Enjoy your builds! Best thing about this hobby!! |
06-27-2022, 10:05 PM | #5 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
I do find that with shocks running "inverted," the oil gets less gunky, or at least takes a lot longer to get gunky. Which is counter-intuitive, but here we are. Never fear embracing the philosophy that "if it's stupid and it works, it ain't stupid." Half my rigs live by this. |
Is this a Dumb Question - Similar Threads | ||||
Sorry for the really dumb question ! | Frank211 | Newbie General | 5 | 05-09-2018 02:01 PM |
Dumb question? | vwmopar | Kyosho Crawlers | 1 | 11-03-2015 08:56 AM |
Dumb Question | Alpha Male | RC4WD Trail Finder 2 | 7 | 09-06-2014 08:30 PM |
Probably a dumb question | Dostradamas | Multi Axle Rigs | 4 | 05-10-2013 10:30 AM |
dumb question. | pavel | Electronics | 8 | 06-10-2005 08:02 AM |
